Master slides not applying in CP6
Aug 20, 2012 7:11 AM
We are getting a recurring problem in CP6.  When the published project is imported into an LMS, some slides appear without the master slide elements.  We have reset the master slides in a test project and published again, still with the problem.
To complicate it more, only one user (our "tester") gets it the most.  I have had it happen occasionally when I go backwards and forwards in a project, but she has it happen all the time, and in more than one LMS.
While it's likely to be something specific to her machine, the problem is that if it happens to her, it may happen to others.
Has anybody seen this?  Can anybody help?
Marion
    Aug 20, 2012 11:45 AM   in reply to MarionJD
    Hello,
    Welcome to Adobe Forums.
    As you mentioned : Untitled.png
    Did you tried upload the LMS package from a different Machine ?
    If your test project's output has the same problem, Did you tried publishing Captivate 6 project from a different user account on that computer ?
    Vikram
