What is the name and location of the AIR Flash Player configuration file? I'm assuming the name should be mm.cfg like it is for the flash palyer on the desktop, where do I put this file when I compile my AIR app?
The "per user" config file, mm.cfg, is outlined here: http://help.adobe.com/en_US/flex/using/WS2db454920e96a9e51e63e3d11c0bf 69084-7fc9.html
If you want to modify the system level mms.cfg, that'll be in your C:\windows\syswow64\macromed\flash folder
Where is the mm.cfg file located when an AIR app is runnning? Or putting it another way, how do I get the AIR app installer to update the mm.cfg file for the user if I develop on a Mac and the user installs the app on windows/linus/another Mac/iOS/Android/QNX/AIR for TV, etc?
How do you programmatically modify the Flash player configuration settings? Is this a pre-launch change or at runtime?
I want to enable AS3Trace and TraceOutputBufferred so I an see where the application is spending most of it's time during certain sections of the application.
