Mike Hoover
Chapter markers not imported from previous version of Premier
Aug 19, 2012 9:15 AM
Tags: #import #marker
When I import a Premier timeline created in CS5 to Encore CS6 the chapter markers don't import.  Yes, they are proper Encore markers which were previously imported ok in Encore CS5.  I find that if I go into Premiere (CS6) and 'Edit Marker' then click Ok (even without changing anything), that marker will then import when markers are reloaded in Encore.
    Aug 19, 2012 9:28 AM   in reply to Mike Hoover
    I'm thinking you can do this in CS5 to CS6, whereas you couldn't in CS4 to CS5. But I would test that by opening the CS5 in CS6 and save as CS6. Any difference? (I assume not.)
    Is there a chapter name in the marker?
    Are you exporting to H.264 or using dynamic link?
    Aug 20, 2012 9:01 AM   in reply to Mike Hoover
    The entire marker system in Pr was overhauled for CS6, so while it's unfortunate, the issue you are having is probably expected.  Markers from projects created in earlier versions of Pr will at some point have to be translated into CS6 markers, and that will have to be done from inside of Pr itself.
    If you want to avoid the Edit/OK dance in CS6, I would recommend finishing your project in CS5.  I wish I had a better or easier answer for you.
    Jeff
    Aug 20, 2012 10:49 AM   in reply to Mike Hoover
    Even if it were snippy, that would be okay. I'm afraid Jeff has the answer. For some files, the chapter info is in the sidecar file (XML?) and might be edited. But by the time you do that, you can just fix each marker in PR.  Double click and save alone did it?
