Process multiple files
Aug 16, 2012 9:42 PM
    Aug 16, 2012 9:42 PM   in reply to Community Help
    I use "process multiple files" to convert a bunch of raw files to high res jpegs. Today it stopped working on version 9...and same issue on version 10.
    It opens and converts but then the "save as" dialog comes up...and can only save in psd format.
    I have used this for years and years and today it just stopped.
    Anyone have any idea how to put back? don't know if it is a Win7 update issue?
    very bizzare.
    Your help and advice is appreciated.
    Aug 16, 2012 9:57 PM   in reply to SKYviewAP
    You probably have the Bit Depth in the camera raw dialog set to 16 bits/channel.
    If you open a raw file and change the bit depth to 8 bits/channel (bottom of the camera raw dialog)  and then press Done,  process multiple files should work on those images.
    Aug 16, 2012 10:44 PM   in reply to R_Kelly
    Bloody Hell, you are a genius...it never seems to amaze me that such a little thing..stuffs up the WHOLE workflow!! I was editing some work in RAW and must have changed it for some stupid reason.
    So much for 12 hours trying to fix!!
    I have been using Photoshop for at least 2004...and never missed a beat till now.
    Now...they say things happen in 3's..I am not going out tonight.
    THANK YOU very much R_Kelly
    Hooraroo
    Aug 17, 2012 2:40 PM   in reply to Community Help
    Having similar but different problem. Saved the raw images to a folder & it appears to have converted to something else.  Now trying to do multiple process to JPEG but file has an extension of NEF - stating wrong type of file. Any tips on how to process these to JPEG & open.  Thxs!
    Aug 18, 2012 12:29 AM   in reply to holapics
    If you have used the 'Save' button in the ACR dialog, your files should have been converted to the Adobe proprietary raw format : DNG.
    Are those 'saved' photos with a .DNG suffix ?
    Aug 20, 2012 1:15 PM   in reply to MichelBParis
    When you look at the file it has the PSE icon - with suffix NEF and the whole numeric read as such:  .DSC_06676.NEF
    I initially saved straight into a folder on my computer.  Then it prompted me to open with---Windows Live photo gallery (which did not work) of course - then realizing I needed to convert it first.  I then tried to do multiple file processing through PSE.  Did not work & since I get message of "saved in the wrong file type".  Not sure what to do from here.  Any other ideas?
    Aug 20, 2012 1:35 PM   in reply to holapics
    Have a look at this:
    http://www.neftojpg.com/
    I've never used it.
    Sep 20, 2012 7:14 AM   in reply to Community Help
    Is it possible to aotomate cropping of faces from a bunch of photos?
    Sep 20, 2012 8:52 AM   in reply to mirzavu144
    It is probably best if you place this new topic in its own thread, instead of placing it in a thread whose topic has nothing to do with your question.
    Oct 3, 2012 12:18 AM   in reply to dj_paige
    Wanted to Say.....Thank you so much!!!! neftojpg---awesome:) it works!!
