Well, so far I"m zero for four in trying to get LR to let me do trivial things the way I'd like, but let's give it yet another try........
I ALREADY KNOW you can use the "[" and "]" to change the size of the spot removal circle. BUT, I'm trying to get LR to work as much like Photoshop as possible 'cause the inconsistencies on small things is a surprisingly large hit to productivity.....
In PS I can change the size of the clone or heal using Alt and the mouse. Change both size AND opacity.
Is this buried somewhere in LR? If not, is there a way for me to define this command in the translatedstrings file?
If so, can someone provide the necessary lua (I think) syntax to do the definition?
You can also change the size of spot-removal circle using the mouse wheel.
As for editing Translatedstrings.txt, the Keyboard Tamer plugin lists most but not all of the keyboard shortcuts that can be set in Translatedstrings.txt. The format is pretty easy to figure out -- look at one of the files for a non-English language.
