I have doing some testing with Illustrator CS6 and have noticed a bug in the Layers panel. If you have a layer with the 'print' option unchecked, i.e making it a Non-Print layer, any layer that resides below it will display incorrectly in the Layers panel (The layer name, previous and any sublayers will disappear until you role over the layer with your mouse).
Has anyone else had this issue, does adobe have a fix for this??
Thank you for the reply.
I have attached a couple of screen shots showing the issue. The first screen shot shows all layers below the layer with 'print' unchecked as not displaying properly. The second screen shot shows all layers displaying correctly when 'print' has been checked again in the layer options.
I am having no problemon Lion but it does sound like a bug or conflict. the question is what manifests this to happen.
I wonder if it starts to happen after they open the print dialog for that file? Or related to a rip or a printer driver conflict?
Although this sounds like a bug to me even though I can't reproduce it.
I am aware of issues with Verdana fonts but Illustrator may use other fonts as well for the panel text depending so if Verdana is disabled and it fixes issues for you. Else you may have to do a trial and error to find out the exact culprit in your case. you may enable all and see if the issue goes away and then look to selectively disable in a bunch to arrive at the font that should have been enabled but is disabled.
Illustrator installers installs few fonts(dont have the list handy) those are the must that needs to be enabled as few of them may be used by user interface.
This is an issue with Arial and non-printing layers. If you have the open type version of Arial deactivated and a nonprinting layer (which is indicated by an italic Arial) all the layers will show up wonky beneath that non-printing layer.
I have repeated this bug over and over using Font Explorer X. Deactivating Arial causes the layer panel to break, reactivating Arial makes the layer panel work normally. The workaround is to activate Arial and make all layers "printing layers" and simply hide them.
I have attached screencast.
I am on 10.6.8 but using Suitcase Fusion 4 and am having the layers panel issue described above (disappearing below non-print layers). I tired activating the open type version of Arial Italic, but that didn't resolve it here. We have two macs and on one the layers panel is fine. They have the same OS, apps, fonts, plug-ins etc. I have reinstalled, repaired disk permissions, cleaned font caches...
Hi all,
I was having the same issue, (the minute I set a layer to non-print, it's name in the layer panel disappeared).
Activating Verdana full time seemed to help. As posted earlier, I am a pro-user, therefore I also use font management (Suitcase Fusion), setting Verdana to "Permanent" fixed the UI bug.
WOW, what timing. After reading up on this issue here on Adobe.com and narrowing down to Verdana or Arial being the issue on the last reply... this update from Extensis Suitcase popped up on my Mac (Mountain Lion, CS6, Suitcase Fusion 4)
"What’s new in Suitcase Fusion 4
What’s new in 15.0.5
This release addresses an issue that caused fonts to be unavailable to the Extensis auto-activation plug-ins and font panels in Adobe applications."
I'm sure there must be a manual fix as noted (try using opentype Arial was posted)
This release addresses an issue that caused fonts to be unavailable to the Extensis auto-activation plug-ins and font panels in Adobe applications. For more information, see this Knowledgebase
Font panels are a different issue. The original discussion was about layers set to non-print. As a recent subscriber to the cloud, I hoped it had been resolved. Following the suggestions above has not helped. I have to set all layers to print, so, not a good work around. Any more input? Thanks!
I am still having the issue, yes. If an Illustrator layer is set to non-print, it and all the layers below it are no longer visible. If I change it back to being a print layer it all views as expected. Since the names of non-print layers are italic, it would seem to be a font issue and it does appear that some people have resolved the issue by activating the right font. Thank you
Yes, that's what I thought. So yes, I found in my case, that it was indeed a font issue. When the correct fonts were permanently activated, then I was able to set layers to non-print, but still be able to read the layer name.
The font in question was Verdana.
Sorry I can't be of any more assistance.
Microsoft Office 2011 is the cause of problem as soon as you install, it will make Ai to act, it is replacing Verdana to MS 5.02 version of font and kills the itlic Verdana which AI is looking for. Here is what I did to fix the issue and it worked. Remove Verdana fonts from Hard Drive > Library > Fonts folder. From the Finder select Finder > Secure Empty Trash. Use Apple's Font Book to look at "All Fonts" and search for Verdana, then right-mouse click on "Verdana" and select "Enable 'Verdana' Family." Quit Font Book. Note : if you have a third party fonts management software like Suitcase please make sure it is activated permanently. Verdana is in apple system font . Good luck .
Verdana! Activating Verdana fixed this for me as well as the issue that the icons in the bottom of the layer's palette were not always displaying or working and I could not move selections using the little dot on each layer. Both issues fixed with permanent activation of Verdana. Super strange but very glad to have a fix. THANK YOU!
