Thank you for having you replay.
I'm going to make AE Plug-In to work on Premiere pro.
I find at the SDK_Noise sample(AE SDK sample), I renewed a part of the "Render" function as follows
and carried it out.
but,
in the case of "src ①", noise_param.u.ld.data is "ARGB" format,
in the case of "src ②", noise_param.u.ld.data is "VUYA" format.
why are formats different "src ①" and "src ②" ?
static PF_Err
Render (
PF_InData *in_dataP,
PF_OutData *out_data,
PF_ParamDef *params[],
PF_LayerDef *output )
else if (destinationPixelFormat == PrPixelFormat_VUYA_4444_8u)
PF_ParamDef noise_param;
AEFX_CLR_STRUCT(noise_param);
ERR(PF_CHECKOUT_PARAM( in_dataP,
0,
in_dataP->current_time,
in_dataP->time_step,
in_dataP->time_scale,
&noise_param));
ERR(suites.Iterate8Suite1()->iterate( in_dataP,
0,
linesL,
&noise_param.u.ld, // src ①
//&params[NOISE_INPUT]->u.ld, // src ②
NULL,
(void*)&niP,
FilterImageVUYA_8u,
output));
ERR(PF_CHECKIN_PARAM(in_dataP, &noise_param));
Source files are different:
eg: DV, MPEG2, MPEG4 is compressed YUV420 -> Converted in Importer to YUVA4444 -> PrPixelFormat_YUVA_4444_8u
MotionJPEG is compressed RGB -> Converted in Importer to BGRA4444 -> PrPixelFormat_BGRA_4444_8u
Apple ProRes 10bit YUV422 -> PrPixelFormat_YUVA_4444_32f
In your plugin register supported PrPixelFormat_* of what you can process.
eg: If you only process PrPixelFormat_YUVA_4444_32f register only that PrPixelFormat.
version<CS5.0 you MUST support PrPixelFormat_BGRA_8u
version>CS6.0 Premiere Pro will convert to your format.
I recommend you make your plugin using PrPixelFormat_YUVA_4444_32f only.
I use version CS5.5.
I supported PrPixelFormat_VUYA_4444_32f in "PF_Cmd_GLOBAL_SETUP".
(*pixelFormatSuite->AddSupportedPixelFormat)(in_dataP->effect_ref, PrPixelFormat_VUYA_4444_32f);
Therefore, I was able to acquire a format of "PrPixelFormat_VUYA_4444_32f" by using GetPixelFormat function in the "Render" function.
However, In the Render function,
A feild of current time("???.u.Id.data") whitch I acquired using PF_CHECKOUT_PARAM function is different from params[0]->u.ld.data.
Why do two data not accord?
[ Two data comparisons (visual studio 2008)]
Hi Zac,
> Have you confirmed that the pixel formats of the two buffers are different using pixelFormatSuite->GetPixelFormat()?
Yes.
「 params[0]->u.ld.data 」 is "PrPixelFormat_VUYA_4444_32f",
「 "???.u.Id.data" 」 is "PrPixelFormat_ARGB_4444_8u".
# 「 "???.u.Id.data" 」is A feild of current time whitch I acquired using PF_CHECKOUT_PARAM function.
I have to get at the data that has been formatted to "PrPixelFormat_VUYA_4444_32f"
to the pixel format of a feild whitch I acquired using PF_CHECKOUT_PARAM is, How do I?
Thanks.
u ch
Ah yes, so in CS5.5 and earlier, frames retrieved from Premiere Pro using PF_CHECKOUT_PARAM() are always 8-bit ARGB.
New in CS6, you can optionally specify that PF_CHECKOUT_PARAM() should pass back frames in the same pixel format being requested by the current render. In the AE CS6 SDK, in PrSDKAESupport.h, PF_UtilitySuite4 contains EffectWantsCheckedOutFramesToMatchRenderPixelFormat(). Your effect should make this call during PF_Cmd_GLOBAL_SETUP, which is the same selector where an effect would already advertise support beyond 8-bit RGB using AddSupportedPixelFormat(). After making that call, the two frames in your example above will be VUYA_32f.
Cheers,
Zac
I understand.
Can you convert it from ARGB to VUYA (from VUYA to ARGB)?
I want to do Next.
1. I convert from ARGB to VUYA.
2. I apply special effect for VUYA.
3. I convert from VUYA to ARGB.
4. I copy ARGB to "output".
Please teach a method to convert.
