LR4 Develop module differs from export file
Aug 20, 2012 7:28 PM
I'm running LR4.1 on Macbook Pro OS X 10.6.8, monitor is calibrated with Spyder3Elite.
I was working on a photo in LR4 and I made adjustments in Develop module until it looks good to me. I exported the RAW file to JPEG with sRGB color profile and applied Standard Sharpening for screen. Here's how it looks:
Left side is LR4 Develop module, Right side is Mac Preview, Soft proofed to my monitor color profile.
I have no problem with the color on both applications and I have given up on the amount of noise that is significantly magnified (even exporting without sharpening gives so much more noise than Develop module displays... ) but look at those stars!!
How come the export shows SO many stars while LR4 Develop module sorta "hides" them? The look on Library module is closer to the exports when it comes to the stars only, but the absence of NR makes it way too horrible to look at longer than a second
Am I doing anything wrong here?
  • Victoria Bampton
    Apr 1, 2008
    Aug 21, 2012 8:39 AM   in reply to iceny
    Try zooming into 1:1 view for a more accurate preview.
  • Victoria Bampton
    Apr 1, 2008
    Aug 21, 2012 9:24 AM   in reply to iceny
    I can't double check this right now - it may have changed - but if you zoom into 1:1 in Library, the Library Fit view will then have the NR applied and look much more like the exported version.  Just try it and let me know, or I'll double check it later.
    Aug 21, 2012 9:25 AM   in reply to iceny
    Not sure about LR4, but in LR3, noise reduction and sharpening were not always applied in develop module except at 1:1 zoom.  I don't know if that's still the case, but it fits with what you are describing.
    The logic: images rendered faster without having to do NR, and you can't really judge noise and sharpening except at 1:1.  In Library module, images are rendered only once (until you edit the image again) so rendering time is not such an issue.
  • Victoria Bampton
    Apr 1, 2008
    Aug 21, 2012 10:13 AM   in reply to CSS Simon
    LR4 does now apply NR in Develop module at lower zoom's, but it's not that accurate, particularly at higher sliders values.
  • Victoria Bampton
    Apr 1, 2008
    Aug 22, 2012 1:08 PM   in reply to iceny
    Excellent!  It's only usually an issue when you have unusually high noise reduction or sharpening settings, but it's a handy workaround to have up your sleeve for those occasions.  If you have a batch of them, you don't need to go through manually zooming in Library - just to go Library menu > Previews > Render 1:1 Previews to get the same result.
