Silverarrow23
PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
Jun 20, 2012 5:03 AM
Tags: #help #error #adobe #mac #dreamweaver #code #phonegap #html5 #cs6
Hey guys, I was wondering if someone could fix this problem, Im having, i have Dreamweaver cs6 on a mac, And im trying to login to phonegap build in dreamweaver, but everytime i try, it tells me that it cannot connect to the servers, plz try again later, is this a known problem?
thanks,
Jonathan
    Jun 25, 2012 3:18 PM   in reply to Silverarrow23
    Jonathan,
    I had the same problem a month ago.  Here is the post:
    http://forums.adobe.com/message/4472028#4472028
    I haven't been able to find a solution and never got a response from Adobe.
    - Loren
    Jun 25, 2012 11:06 PM   in reply to Silverarrow23
    Be sure you have installed the latest updates for your Adobe CS6 software. Go to Help > Updates to ensure you have the latest. One in particular that you need to install is for CSXS, although I do not recall the exact name of it.
    After updating, restart your computer to ensure the associated background services are refreshed.
    If it's still not working then, there are a couple of log files we would want to check what is going on at your end. These are called "init_status.txt" and "auth_status.txt" and are found in a folder called "PGB" in /Users/<YOUR USER NAME>/Library/Application Support/Adobe on Mac OS, or C:\Users\<YOUR USER NAME>\AppData\Roaming\Adobe on Windows 7.
    Jun 29, 2012 12:29 PM   in reply to Carey Burgess
    Carey,
    I checked on updates and there were two:
    Speed Grade CS6 6.0.1
    DPS Desktop Tools CS6 2.0.2
    I've updated CS6, restarted, but had the same error.
    I've searched for the two files you mention and I do not have the PGB folder or the files on my computer.
    What should I try next?
    Thanks for trying to help out with this.  I have notice that I am not the only one experiencing this.
    Calculating status...
    Jul 10, 2012 4:12 PM   in reply to lybarrondo
    I have the same problem, very frustrating.
    Jul 11, 2012 2:59 AM   in reply to bwroberts
    What is the size of the build?  Mine is over the 10 meg limit set by phonegap.  I was going to try a smaller build size to see if that was the problem.
    Jul 13, 2012 1:06 PM   in reply to lybarrondo
    If you're not able to connect from within Dreamweaver, have you tried logging into PBG directly?
    https://build.phonegap.com/
    Jul 13, 2012 1:36 PM   in reply to Silverarrow23
    I can build using github and PGB directly (i.e., not using CS6).    That's not really a solution though as a major consideration in upgrading to CS6 was this feature.
    Jul 13, 2012 2:42 PM   in reply to lybarrondo
    Thanks for confirming that you can log in directly.
    Can you check for the log files I mentioned above?
    The logs should help us identify why it's failing for you.
    Let me know if you have any difficulty locating these files.
    Jul 19, 2012 6:44 AM   in reply to Silverarrow23
    I too am having this problem.
    My dreamweaver is up to date and I have checked for those txt files and only have "auth_token.txt".
    It says "{error:'Authentication Failure. Could not connect to server.'}"
    Thanks for any help.
    Aug 20, 2012 3:05 PM   in reply to Silverarrow23
    Having the same problem - no solution found so far...
    Aug 20, 2012 9:08 PM   in reply to lybarrondo
    did u check that your files were not hidden?
    Aug 21, 2012 9:29 AM   in reply to mwolsten1
    Hello guys,
    Not sure if this will help anyone else, but it helped me move along with my project.
    I was having the issue "Looks like we are having some server issues... etc.".
    I read that there is a size limit of 10 mb. Which could be tough to work with for some people. This includes EVERYTHING in your site directory, so if you're keeping some photoshop files in an "images" directory or something, it will try to upload those as well, and fail. I removed everything except the necessaties from my site directory, and it created a new Phonegap project without any problems.
    Hope that helps someone.
    Aug 21, 2012 11:03 PM   in reply to Carey Burgess
    I am having exactly the same problem.
    Can manually login at the PGB-website but not with DW CS6.
    The files init_status.txt and auth_status.txt doesn't exist on my system, just the file auth_token.txt with the same content as bepongchris reported.
    The size limit is not the problem as this already happens when trying to login not when uploading a build. And of course I tested with a tiny test site.
    I am still stuck.
    Aug 22, 2012 8:54 AM   in reply to Carey Burgess
    Same problem here. So please, ADOBE, help!
    Aug 24, 2012 5:48 PM   in reply to Silverarrow23
    I was having this same problem. I ran the CS6 updates (Help > Updates...) then deleted all the chaff from my source directory (inc. a lot of unused videos) and then build completed fairly quickly.
    An informative error message wouldn't have gone amiss though...
    Sep 21, 2012 5:22 AM   in reply to Carey Burgess
    m facing same problom after login please help ????
    look @ this issues
    We're sorry, but something went wrong.
    We've been notified about this issue and we'll take a look at it shortly.
  • Sudarshan Thiagarajan
    Oct 15, 2010
    Sep 22, 2012 6:28 AM   in reply to Silverarrow23
    Can you post a screenshot of your folder hierarchy here - your main site folder and the subfolder where you're trying to use the PhoneGap Build for your app/ site.
    The 10MB limit is not only for the mobile site. If your mobile site folder resides within a main site folder, PhoneGap Builder calculates the 10MB limit for your parent folder. This may be the culprit?
    Sep 22, 2012 6:53 AM   in reply to Sudarshan Thiagarajan
    I have already resolved this problem......thanx
    Oct 15, 2010
    Sep 22, 2012 6:55 AM   in reply to kamal kant jangra
    Can you share how you did? Maybe that could help the other users who may be looking for a solution.
    Sep 22, 2012 7:00 AM   in reply to Sudarshan Thiagarajan
    my adobe ID is not linked in phonegap. so i have linked my ID with phonegap and its working fine....
    Sep 23, 2012 2:47 AM   in reply to kamal kant jangra
    @kamalkant: what do you mean by "link the adobe ID"? how did you do that?
    Sep 23, 2012 5:03 AM   in reply to Misi
    hi misi
    go to this link https://build.phonegap.com/people/edit
    and linked your ADOBE ID and Github Account.
    Sep 23, 2012 5:24 AM   in reply to kamal kant jangra
    any one please help.... how to access ios signing key
    Oct 15, 2010
    Sep 23, 2012 6:55 AM   in reply to kamal kant jangra
    Please create a new thread here: http://forums.adobe.com/community/dreamweaver/dreamweaver_general
    This thread is going out of the scope of the OP's original question.
    Oct 17, 2012 11:04 AM   in reply to Silverarrow23
    it is may be because a free phonegap service account allows you to upload only one app. you have to delete the old app before uploading another one.
    Oct 17, 2012 11:07 AM   in reply to kamal kant jangra
    i have my adobe id linked with PGB but am still having the same problem.
    Oct 17, 2012 11:18 AM   in reply to varun r ramani
    that's not true. I have checked at all... you can build more than one with multiple app. are you using dreamweaver with build service or through phonegap website???
    Mar 28, 2013 11:21 PM   in reply to Carey Burgess
    1. I have a phonegap account and it's linked to the Adobe account;
    2. Logging in phonegap.com and compiling my apps in their website, works just fine;
    3. I have always Dreamweaver signed in to the Adobe account;
    4. Here are the content of my files:
    init_status.txt:   {"message": "Failed to upload application. Unable to create zip file. Reason: null","error": 404}
    auth_status.txt:    {"statusCode": 200,"statusMessage": "Authenticated"}
    Hope this helps you help us.
    I just want to say that this was THE feature that made me buy CS6 in the first place, and it's not working as intended.
    Apr 1, 2013 1:59 AM   in reply to Arcanelight
    What version of Dreamweaver are you using? Go to Help – About Dreamweaver and provide us the Dw version and build number.
    If you are not on latest version please click on “Help – Updates” and update Dw to latest version. (12.0.3 or 12.2 are must for PGB)
    login to https://build.phonegap.com/ and try to build an app directly here. Let us know if you are able to do so.
Bookmarked By (1)
