jkwest1s88
CS5 disc will not run.
Aug 19, 2012 8:27 PM
Tags: #cs5 #disc #installation #driver #readme
I purchased Photoshop CS5 Extended a little while ago from my campus bookstore. I just had the chance to crack the box open and install. I followed the directions on the box and went online to get my student licensing serial number- making the purchase nonrefundable. I inserted the disc, and waited... and waited... and it never ran. I went in to my computer (HP Pavilion dv4, Intel Core2 Duo T6500 @ 2.1 GHz, 4GB RAM, 64 bit) and tried to force install on the disc drive, but the computer did not recognize that the disc was even readable. I removed it, inserted a movie, and it played just fine. I even installed updates to my computer, restarted the system, and tried again- same result. Am I stuck with this lemon? Please help! I'm on a grad school budget and can't afford to buy a new disc just because the one I just registered won't even read brand new out of the plastic wrap...
    Aug 20, 2012 10:42 AM   in reply to jkwest1s88
    If you right click on the disc and select Open what happens?
    Aug 20, 2012 11:08 AM   in reply to jkwest1s88
    If you put the disc in another computer is it able to mount successfully?
    To obtain the install files you can follow the directions listed at http://prodesigntools.com/all-adobe-cs5-direct-download-links.html to download the install files for Photoshop CS5.
    Aug 22, 2012 8:03 AM   in reply to jkwest1s88
    If you can get the disc to mount on another computer then please copy the install files to a USB drive.
    Alternately you can try the direct download option again.  Perhaps try a different web browser?  The key part is you need to have initiated a download of the trial prior to clicking on the direct download links.  Otherwise you will receive the Access Denied error message.
    Aug 23, 2012 10:45 AM   in reply to jkwest1s88
    I provided a link for this already please see message #5 in this thread.
