Al.Boulley
Export Book as ePub - an order option greyed out
Aug 20, 2012 7:26 PM
Tags: #cs5 #export #book #cs6 #epub #articles_panel #content_order
Hello All... so after doing some fruitless searching online and in this forum, I must ask about this problem I've run into.
I am having the same problem within ID 5.5 on Windows and ID 6 on both Mac and Windows.
What I want to do is "Export Book to EPUB..." while also using the Articles Panel ordering I've set up in the documents. I am trying to do this with several different Books, and getting the same problem when in the Export Options.
I would like to select "Same as Articles Panel" as the option for "Content Order", but it is greyed out. What is even more frustrating is that *one time* the option was selectable, and the export worked as expected. I have no idea whatsoever why InDesign allowed me that one time to select the "Same as Articles Panel" option, yet every other time I try, it is greyed out and I cannot choose that option.
Would love to hear from some experts on this one. Thanks in advance for anyone's time and effort.
    Aug 20, 2012 7:41 PM   in reply to Al.Boulley
    Did you check the checkbox beside each article you created? Like this:
    If you did that, then Same as Articles Panel should be available.
    If it still is not, then you should try restoring your preferences:
