wanting1989
An old problem: Text doesn't show in AE cs3?
Aug 20, 2012 11:37 PM
I'm a beginner in AE, just downloaded a free template from http://www.freeaetemplates.com/
I try to change the text and logo in the template, but the text just doesn't show:((. Click Reset Character and change current Time Indicator doesn't work. I also installed the missing fonts in the template but still no luck. Could you please help me pointing out my problem and how to fix this?
My OS info: Window 7, Adobe After Effect CS3.
    Aug 20, 2012 11:52 PM   in reply to wanting1989
    Layer Styles? A "bad" font on the system? Matte/ transparency options? Effects? OpenGL?
    Mylenium
    Aug 21, 2012 2:09 AM   in reply to wanting1989
    One more thing: Is there a text animator for opacity/ scale? Hit U or UU to revela all animated/ changed parameters...
    Mylenium
    Aug 21, 2012 7:51 AM   in reply to wanting1989
    You are aware that this is effectively hiding whatever text there is? Turn it off/ animate it differently/ move to anotehr time in the comp.
    Mylenium
    Aug 22, 2012 9:16 AM   in reply to wanting1989
    Try this first. Turn on transparency grid at the bottom of your composition window. It's the icon that looks like a mineature checkerboard just to the left of the Composition Camera selector. If you don't see any text declect all layers, select the type tool and type a few characters in the comp window. If you still don't see anything make sure that your previews are not set to wireframe. If you do see text then there's a setting you're missing or a keyframe you're behind in the timeline. Look there.
