Seth McGraw
CS6 form creation not allowing tables to be used.
Aug 21, 2012 8:21 AM
I have created a form to be exported to pdf, however none of the table contents output as text boxes. Is there a way to have this happen, or a way to convert the table into individual boxes to be assigned? The form has approx 800 boxes which need to be available for input. As an experiment I created a simple 16 x 10 table with plain empty cells and exported to pdf. acrobat ignored the table even after cycling it through the auto-detect wizard.
Any ideas?
I posted this on the acrobat forum to no avail.
    Aug 21, 2012 8:44 AM   in reply to Seth McGraw
    Did you put form fields into the document?
    Bob
    Aug 21, 2012 9:17 AM   in reply to Seth McGraw
    I’m not sure where you got that idea, but no.
    If you want text fields there, you’ll need to add them using the form tools in either InDesign or Acrobat.
    Bob
    Aug 21, 2012 10:23 AM   in reply to Seth McGraw
    Are you saying you ran the form detection in Acrobat Pro and it didn't work?
    Bob
    Aug 21, 2012 10:59 AM   in reply to Seth McGraw
    I don’t have an explanation for that except to tell you that as good as it is, it’s not perfect.
    Did you make the table cells large enough? Are there strokes on the cells?
    Bob
    Aug 21, 2012 11:15 AM   in reply to Seth McGraw
    Start here: http://www.theindesigner.com/blog/episode-52-acrobat-friendly-form-des ign
    But I don’t understand why you don’t want to do this in InDesign using the form tools there.
    Bob
    Aug 21, 2012 11:23 AM   in reply to Bob Levine
    You can convert a table in ID to text fields in acrobat using the wizard to detect form fields. Make sure you type the text labels in the table header.
    You cannot directly convert a table to a group of text fields directly from ID using Button and form panel.  But you can 'gridify' a rectangle into a grid and then select all the rectangles and convert to a text field.
    Aug 21, 2012 11:41 AM   in reply to Seth McGraw
    Why not draw a text field with the forms and buttons panel and then use step and repeat to copy it to other cells.
    Bob
