Please Help - Randomly HTTP 503 Internal server error
Aug 9, 2012 12:04 AM
Tags: #server #iis #cf10 #tomcat_connector
Hi all,
I have a Coldfusion 10 standard Edition installation with MSSQL 2005 on Windows Server 2008 R2 server about 2 week old.
It is one of my live server and it is dealing with medium to high volume of traffic.
Since deploying this server, it has been getting random HTTP 503 internal server errors,
which require the entire server restart (as coldfusion application server, IIS restart will not able
to resolve the problem). Within this two weeks, sometimes it can last for couple of days without problem,
and sometimes it require 4-5 times server restart within one day.
I can't replicate the error on demand, but I could paste one of the windows server event log here:
          Faulting application name: w3wp.exe, version: 7.5.7601.17514, time stamp: 0x4ce7afa2
          Faulting module name: isapi_redirect.dll, version: 1.2.32.0, time stamp: 0x4f745a78
          Exception code: 0xc0000005
          Fault offset: 0x000000000000cd68
          Faulting process id: 0xfd4
          Faulting application start time: 0x01cd745ad58e3393
          Faulting application path: c:\windows\system32\inetsrv\w3wp.exe
          Faulting module path: C:\ColdFusion10\config\wsconfig\1\isapi_redirect.dll
          Report Id: 144b3231-e04e-11e1-8e6d-00505687001e
And I started suspecting the problem is because the connector comes with coldfusion 10, based on one of the bug reports from apache
https://issues.apache.org/bugzilla/show_bug.cgi?id=48826.
Based on the information in log file, they are pretty similar.
Any suggestions on how to fix this random server error would be greatly appreciated!
Many thanks
Ryan
    Aug 12, 2012 4:05 PM   in reply to Ryan Luo
    Is there anything in the CF or Tomcat logs?
    Adam
    Aug 17, 2012 5:32 PM   in reply to Ryan Luo
    https://issues.apache.org/bugzilla/show_bug.cgi?id=45063
    Use "LocalSystem" for DefaultAppPool identity.
    Van
    Aug 18, 2012 7:03 AM   in reply to Ryan Luo
    Luo,
    You're not the only one having this problem. I removed CF9 after migrating to CF10 and all systems failed. I get the same results as you. I'm going back to 9.
    Aug 21, 2012 2:05 PM   in reply to Ryan Luo
    I'm having the same issue, IIS 7.5 on Windows Server 2008 64bit.  The issue will cause the application pool to crash specifically when doing a cffile action="upload".  My logs are showing the exact same errors as yours both in ColdFusion and in the Windows Event viewer.
    Is there a bug submission somewhere where I can vote this issue up?
    Aug 21, 2012 7:47 PM   in reply to Ryan Luo
    It is in a brand new server that is being tested for production.   I can replicate the crash every time, the server will work fine until I do a cffile action=upload.  The application pool will then crash causing the server to stop responding.   This is on a Windows 2008 Server 64bit, IIS 7.5, and ColdFusion 10.
    Aug 24, 2012 12:06 PM   in reply to Ryan Luo
    I think I reduced my problem as far as I can go.  Its not the CFFILE operation itself, its with a http request with a large amount of content, such as doing an XHR file upload.   This causes the IIS connector to tomcat to throw numerous errors.  If your thread pool is set to die after x number of errors the pool will crash leaving the server unresponsive.  My solution was to do traditional form based file uploads instead of using XHR.
    Aug 28, 2012 8:45 AM   in reply to Ryan Luo
    Ryan, I am having the same issue.  I tried the change that Van suggested above, so we'll see that it works.  I used the advice in the article in his link to change the account that the IIS 7.5 application pool runs under.  You can learn more about changing it here:  http://technet.microsoft.com/en-us/library/cc771170%28v=ws.10%29.aspx .  I would never have found it otherwise--it is tucked in application pool > advanced settings > process model - identity.  Change to LocalService and hope for the best.
    If you solve it though some other method, please post as I have 5 servers ready to go into production once this issue is solved.
    Aug 29, 2012 10:53 AM   in reply to Ryan Luo
    We're getting the same issue on our CF 10 server too. It'll run fine for an hour or two, then fill up the coldfusion-error.log with about 4Mb of this error - over and over. Often the system will choke at this point.
    I can not say whether or not this is related to our ongoing issue with support: trying to get CF10 and ASP4 to run at the same time:
    Aug 29, 2012 10:43:28 AM org.apache.coyote.ajp.AjpProcessor getRealPathFromServer
    SEVERE: Error in getRealPathFromConn
    java.net.SocketException: Connection reset by peer: socket write error
        at java.net.SocketOutputStream.socketWrite0(Native Method)
        at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:92)
        at java.net.SocketOutputStream.write(SocketOutputStream.java:124)
        at org.apache.coyote.ajp.AjpProcessor.getRealPathFromServer(AjpProcessor .java:391)
        at org.apache.coyote.ajp.AbstractAjpProcessor.getRealPath(AbstractAjpPro cessor.java:1112)
        at org.apache.naming.resources.FileDirContext.doGetRealPath(FileDirConte xt.java:198)
        at org.apache.naming.resources.BaseDirContext.getRealPath(BaseDirContext .java:412)
        at org.apache.catalina.core.StandardContext.getRealPath(StandardContext. java:4475)
        at org.apache.catalina.core.ApplicationContext.getRealPath(ApplicationCo ntext.java:414)
        at org.apache.catalina.core.ApplicationContextFacade.getRealPath(Applica tionContextFacade.java:335)
        at coldfusion.runtime.ServletContextWrapper.doGetRealPath(ServletContext Wrapper.java:184)
        at coldfusion.runtime.ServletContextWrapper._doGetRealPath(ServletContex tWrapper.java:116)
        at coldfusion.runtime.ServletContextWrapper.getRealPath(ServletContextWr apper.java:98)
        at flex.util.ServletPathResolver.resolveRealPath(ServletPathResolver.jav a:55)
        at flex.util.ServletPathResolver.deduceFile(ServletPathResolver.java:30)
        at flex.util.PathResolver.resolveFile(PathResolver.java:111)
        at flex.compiler.CachedComponentLoader.createSourceFileAppRoot(CachedCom ponentLoader.java:634)
        at flex.compiler.AppRootASClassLoader.createSourceFile(AppRootASClassLoa der.java:33)
        at flex.compiler.CachedComponentLoader.hasClassName(CachedComponentLoade r.java:832)
        at flex.compiler.linker.Loader$1.fetch(Loader.java:406)
        at macromedia.util.SoftCache.get(SoftCache.java:81)
        at flex.compiler.linker.Loader.getClassName(Loader.java:395)
        at flex.compiler.CompositeLoader.hasClassName(CompositeLoader.java:198)
        at flex.compiler.linker.Loader.findClassName(Loader.java:383)
        at macromedia.asc.AsPackageManager.getAsPackage(AsPackageManager.java:19 0)
        at macromedia.asc.AsCompiler.loadSymbolTable(AsCompiler.java:1208)
        at macromedia.asc.AsParse.loadSymbolTable(AsParse.java:7714)
        at macromedia.asc.AsParse.loadSymbolTable(AsParse.java:7653)
        at macromedia.asc.AsParse.parseMemberExpr(AsParse.java:992)
        at macromedia.asc.AsParse.parseLeftHandSideExpr(AsParse.java:794)
        at macromedia.asc.AsParse.parsePostfixExpr(AsParse.java:757)
        at macromedia.asc.AsParse.parseUnaryExpr(AsParse.java:1472)
        at macromedia.asc.AsParse.parseCastExpr(AsParse.java:1303)
        at macromedia.asc.AsParse.parseMultiplicativeExpr(AsParse.java:676)
        at macromedia.asc.AsParse.parseAdditiveExpr(AsParse.java:637)
        at macromedia.asc.AsParse.parseShiftExpr(AsParse.java:1478)
        at macromedia.asc.AsParse.parseRelationalExpr(AsParse.java:1515)
        at macromedia.asc.AsParse.parseEqualityExpr(AsParse.java:1581)
        at macromedia.asc.AsParse.parseBitAndExpr(AsParse.java:1679)
        at macromedia.asc.AsParse.parseBitXorExpr(AsParse.java:1655)
        at macromedia.asc.AsParse.parseBitOrExpr(AsParse.java:1632)
        at macromedia.asc.AsParse.parseAndExpr(AsParse.java:1703)
        at macromedia.asc.AsParse.parseOrExpr(AsParse.java:1738)
        at macromedia.asc.AsParse.parseConditionalExpr(AsParse.java:1773)
        at macromedia.asc.AsParse.parseAssignmentExpr(AsParse.java:1801)
        at macromedia.asc.AsParse.parseExpression(AsParse.java:1899)
        at macromedia.asc.AsParse.parseStatement(AsParse.java:6215)
        at macromedia.asc.AsParse.parseBlock(AsParse.java:2294)
        at macromedia.asc.AsParse.parseFunction(AsParse.java:3140)
        at macromedia.asc.AsParse.parseStatement(AsParse.java:6091)
        at macromedia.asc.AsParse.parseToplevelStatements(AsParse.java:2187)
        at macromedia.asc.AsParse.parseStatements(AsParse.java:2162)
        at macromedia.asc.AsParse.compileScript(AsParse.java:7126)
        at macromedia.asc.AsCompiler.parseString(AsCompiler.java:1083)
        at macromedia.asc.ActionScriptCompiler.parseOnly(ActionScriptCompiler.ja va:76)
        at flex.compiler.CodeGenContext.parseOnly(CodeGenContext.java:135)
        at flex.compiler.WatcherVisitor.compileAndReplaceFunctions(WatcherVisito r.java:172)
        at flex.compiler.WatcherVisitor.execute(WatcherVisitor.java:150)
        at flex.compiler.WatcherVisitor.doWatcherPass(WatcherVisitor.java:1562)
        at flex.compiler.SwcBuilder.createClass(SwcBuilder.java:646)
        at flex.compiler.SwcBuilder.createSwc(SwcBuilder.java:80)
        at flex.compiler.MxmlLoader.compileComponent(MxmlLoader.java:410)
        at flex.compiler.J2eeMxmlCompiler.compileSourceEntry(J2eeMxmlCompiler.ja va:60)
        at coldfusion.tagext.html.form.CFFlexApi$CompileMxml.run(CFFlexApi.java: 412)
        at java.security.AccessController.doPrivileged(Native Method)
        at coldfusion.tagext.html.form.CFFlexApi.compile(CFFlexApi.java:226)
        at coldfusion.tagext.html.form.MxmlOutput.compileMXML(MxmlOutput.java:65 )
        at coldfusion.tagext.html.form.MxmlOutput.compile(MxmlOutput.java:53)
        at coldfusion.tagext.html.form.FormTag.doEndTag(FormTag.java:878)
        at cfadmin2ecfm274100841._factor49(D:\webserve\intraweb\fobs\wfas\admin. cfm:2010)
        at cfadmin2ecfm274100841._factor50(D:\webserve\intraweb\fobs\wfas\admin. cfm:35)
        at cfadmin2ecfm274100841.runPage(D:\webserve\intraweb\fobs\wfas\admin.cf m:1)
        at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:244)
        at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:444)
        at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
        at coldfusion.filter.IpFilter.invoke(IpFilter.java:64)
        at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:443 )
        at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40)
        at coldfusion.filter.PathFilter.invoke(PathFilter.java:112)
        at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:94)
        at coldfusion.filter.BrowserDebugFilter.invoke(BrowserDebugFilter.java:7 9)
        at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePers istenceFilter.java:28)
        at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
        at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46)
        at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
        at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
        at coldfusion.filter.CachingFilter.invoke(CachingFilter.java:62)
        at coldfusion.CfmServlet.service(CfmServlet.java:204)
        at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:8 9)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Appl icationFilterChain.java:305)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationF ilterChain.java:210)
        at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringS ervletFilter.java:42)
        at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46 )
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Appl icationFilterChain.java:243)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperV alve.java:224)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextV alve.java:169)
        at org.apache.catalina.authenticator.AuthenticatorBase.invoke(Authentica torBase.java:472)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.j ava:168)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.j ava:98)
        at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java: 928)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineVal ve.java:118)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.jav a:414)
        at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:203)
        at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process( AbstractProtocol.java:539)
        at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoin t.java:298)
        at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExec utor.java:886)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor .java:908)
        at java.lang.Thread.run(Thread.java:662)
    Aug 29, 2012 11:13 AM   in reply to AlHolden
    Upon further review of the logs here, it's possible that these events could be triggered by CF's invocation of flash forms (ie CFFORM type='flash'). They seem to coincide in close proximity.
    Aug 29, 2012 11:15 AM   in reply to AlHolden
    Everyone should "vote" for the bug that was entered for this.  That will help show Adobe that more than one user is experiencing the issue.
    https://bugbase.adobe.com/index.cfm?event=bug&id=3318104
    Aug 29, 2012 11:20 AM   in reply to Miguel-F
    Miguel,
    I added my vote.
    Ryan
    Aug 29, 2012 11:23 AM   in reply to AlHolden
    AlHolden,
    I've noticed that the connector definately crashes when there is a http request with a large content payload.  If I do a HTML5 file upload the server will crash immediately.  Do your forms submit a large amount of data in the post?
    Ryan
    Aug 29, 2012 11:40 AM   in reply to @bittersweetryan
    Yes Ryan, it seems to be fairly consistent with a large request.
    I earlier stated that the issue might have been related to flash form invocation/compilation - but it could also be due to the fact that these forms are starting off with some grids that are pretty heavily populated with data on first load.
    Al
    Aug 29, 2012 9:23 PM   in reply to AlHolden
    We are working on a fix for this issue via
    https://bugbase.adobe.com/index.cfm?event=bug&id=3222748
    Hemant
    Adobe ColdFusion
    Sep 7, 2012 12:59 PM   in reply to hemant_k
    I just posted on the other thread that I had tried the an alternate connector (tomcatiis.riaforge.org).
    It seems to work well with ASP.net and does not require any ISAPI support, though it does require a little more work to install since it is 3rd party.
    I used instructions from this blog post:
    http://boncode.blogspot.com/2012/06/cf-coldfusion-10-experimenting-wit h.html
    Sep 18, 2012 4:30 PM   in reply to Ryan Luo
    Eact same issue here.  Our CF10 rollout to production was a disaster.
    Fault offset: 0x0000000000018b93
    Faulting process id: 0x11f0
    Faulting application start time: 0x01cd950afc876c76
    Report Id: 98760e12-00ff-11e2-9e13-00155d015102
    Sep 26, 2012 7:01 AM   in reply to Ryan Luo
    its obvious that your server is unable to handle the request due to maintenance or a temporary overload of the server; try to find what makes it overloaded!
    Sep 26, 2012 8:08 AM   in reply to Ryan Luo
    With my experience, 503's are caused by slow pages eating up the worker threads. I recently installed CF10 and noticed right off the bat that it is slower that CF9 so the combination of the two either caused or exacerbated your problem. Now I just installed CF10 and have not done any fine tuning yet. When I upgraded to CF9 I remember similar problems that fine tuning solved -- but the problems did not show up right out-of-the-box like they have with CF10.
    Sep 26, 2012 10:18 AM   in reply to TALAL MANAA
    Talal/Steve,
    It's obvious that you did not read the bug report linked to above.  This has nothing to do with server load.  You can crash a server with zero load instantly with this bug.  ANY CF10 server on IIS.  It's not a configuration issue or a capacity issue.  It's a crashing bug, plain and simple.
    Sep 26, 2012 10:28 AM   in reply to roland.collins
    I was going by the initial question and my experience. No, I did not follow the bug link and there are several links in this thread and I didn't have time to read this thread and the associated links in detail. Sorry if I offended anyone.
    Jun 4, 2013 1:07 AM   in reply to Ryan Luo
    Wow, this is still not fixed? Incredible.
    Things like xhr file uploads crash the server as stated in this thread.
Bookmarked By (1)
