I have a .exe file that has about 90 frames. All of the frames work fine with the "full screen command" BUT when I click a button to go to a frame that calls a swf file to a specific position on the stage and a specific size to the swf-the Full screen goes to the regular stage size. AND when I exit that frame it doesn't go back to the larger Full Screen Command.
Flash CS 5.5 AS3 WIN 7 64 bit.
I have other frames that play a swf file(movie) at a certain size and position and they work fine. But this one swf file doesn't. I created all the other files except this swf file. I got from someone about 7 years ago-if that makes a difference.
Any ideas?
So you've set your main document up as:
import flash.display.StageDisplayState;
import flash.display.StageScaleMode;
import flash.display.StageAlign;
stage.scaleMode = StageScaleMode.NO_SCALE;
stage.align = StageAlign.TOP_LEFT;
stage.displayState = StageDisplayState.FULL_SCREEN;
My first assumption would be, because you said it's been 7 years, that person is using ActionScript 2.0. So you're loading an AS2.0 doc into an AS3.0 doc which will have some limited functionality.
Try replacing the 7 year old SWF you're loading with a dummy quickly made AS3.0 placeholder and see if your issue goes away. Chances are it will.
