My menu-bar works just fine. Hovering the links I get the text to take display the desired color. Now I want the menu-item of the selected page to show a third color.
With live-code enabled in Dreamweaver CS6, I can see the following code being generated by the Dynamic menu:
<script type="text/javascript" src="/CatalystScripts/Java_DynMenusSelectedCSS.js"></script><!-- Dynamic Menu Begin CSS Output --><div id="cat_549633_divs"><ul id="nav_549633"><li class="selected"><a href="/home.html">Home</a></li><li><a href="/leistungen.html">Leistungen</a></li><li><a href="/uhrenservice.html">Uhrenservice</a></li><li><a href="/versteigerungen.html">Versteigerungen</a></li><li><a href="/diamanten.html">Diamanten</a></li><li><a href="/ueber_uns.html">Ãœber uns</a></li><li><a href="/kontakt.html">Kontakt</a></li></ul></div><script type="text/javascript">catSetSelectedCSSItem('nav_549633');</script><!-- Dynamic Menu End CSS Output -->
The class .selected is being created in the first list-item (home) as this is the current page.
And here is my CSS:
#nav_549633 {
float: right;
list-style-type: none;
padding-top: 5px;
#nav_549633 li {
float: left;
text-align: left;
#nav_549633 li a {
color:white;
text-decoration: none;
margin: 0 27px 0 0;
font-size: 13px;
text-transform: uppercase;
#nav_549633 li a:hover {
color: yellow;
.selected {
color: green;
The font color green does not appear. It is still white.
In order to see if the class is "working" I tried some other attributes, that DO work!
.selected {
color: green;
padding: 20px
background-color: blue;
In this case, the item appears as a blue box with 20px-padding, just as expected - but the font-color is still white.
Can anyone help me?
Herman
Hello Ginoem50,
Looking at your css it looks like the selected class is not working because the #nav_549633 li a is more specific so it is the one that is listened to.
change .selected to #nav_549633 li.selected a and it should work.
Hope this helps,
Chad Smith | http://bcgurus.com/Business-Catalyst-Templates for only $7
Hello Ginoem50,
Hope this helps,
Hi there,
I want three things to change in my dynamic menu, it's all retalted so i thought i post them here:
Thank for all the help.
Hi Frank,
You need to post a URL here so that people can Firebug the code and tell you how to do it.
Cheers,
-mario
Hi Mario,
Here's the link to my site:
http://grootaartseuronics.businesscatalyst.com/index.html
I have found a solution myself for 2 of the 3 questions i had:
I have deleted/changed this div: #nav_1371057 li li
And created a few new ones:
#nav_1371057 li li a, #nav_1371057 li li a:visited (To control the link en visited link colors in the sub-menu other than the root-menu)
#nav_1371057 li li a:hover (to control the hover in the sub-menu other than the root-menu if nessesary)
#nav_1371057 li li.selected a (to control the selected link and let the link change color or bolder like in my case)
Here are the CSS styles I used:
#nav_1371057 li li.selected a { /*Dit veranderd de dikte (bold) van de geselecteerde link in het submenu, dus de pagina waar je bent*/
font-weight:bolder;
#nav_1371057 li li a, #nav_1371057 li li a:visited{
background: #006;
color:#ffffff;
#nav_1371057 li li a:hover{
background: #999;
color:#ffffff;
Only thing i can't figure out is how I can change/control the color of the arrow which is black now. And i want to make it blue.
Frank
Hi Frank,
Whenever you click on a menu item it will have a class called "selected" applied to it's LI. You can use this class to set the color of the link text e.g.
.selected a {color:red}
See this screenshot:
-mario
Hi Mario,
Yes i use the selected state to make the selected link bolder.
Is there a way to change the color of the arrows?
Thank,
Frank
That's actually not possible, Frank. You'd need to disable the arrows in admin and then use CSS to apply your own arrow as a background image.
Cheers,
-mario
Try adding #nav_549633 li a to your .selected css to become #nav_549633 li.selected a {color: green;} to ensure you target the specific a link. In your css above the green is applied to the li tag and is then replaced by the more specific #nav_549633 li a declaration which puts it white again.
Steve
Hi Chad, hi Steve,
thank´s a lot to you both, as your answers ARE the solution to the problem. You made my day.
Lots of greetings from Germany,
Cheers,
Hermann
Hi Hermann,
ich glaub Chad war ein bisschen schneller mit der richtigen Antwort, waere nur fair ihm die Ehre zu geben
Nicole - BCGurus.com
Hi Nicole,
wo du Recht hast hast du Recht. Hab die Änderung durchgeführt.
Bin übrigens völlig überrascht, eine Antwort in perfektem Deutsch zu bekommen!?
Liebe Grüße aus Mannheim,
Hermann
Haha danke, sehr nett! Wir sammeln unsere Punkte wann und wo wir koennen
Haette ja auch gar nicht geantwortet, haettest du nicht aus Deutschland gegruesst. Und dann noch aus Mannheim! Meine alte Uni-Stadt!
Bin gebuertig aus Potsdam, lebe seit 2 Jahren in Denver. Schoen mal was von einem BC Nutzer aus Deutschland zu hoeren
LG,
Nicole
Das ist der Hammer!
Wie groß ist die Wahrscheinlichkeit, dass sowas passiert? Die geht so ziemlich gegen 0! Umso schöner ist es, dass es dann eben doch passiert
Ich lebe und arbeite hier seit 3 Jahren (in U6) und komme aus der Nähe von Speyer (also gleich um die Ecke!)
Wann uns was hast du hier studiert?
LG,
Hermann
N4 fuer 3 Jahre Digitale Medien an der DHBW Mannheim. Schoene Zeit!
Dann waren wir ja vielleicht mal sozusagen Quadrat-Nachbarn! Find ich klasse!
Auch ich wünsche Dir eine gute Zeit.
Liebe Grüße an die Potsdamer Mannheimerin...
Hermann
