How to make sharp inner beveled corners?
Aug 24, 2012 8:22 AM
I am wonder if it is possible, when using the bevel and emboss tool in the layer style menu, to make a sharp inner corner?
I was working on creating a frame using hard chisel bevel - it makes the outside of the frame have a sharp corner, but the inside is rounded. See sample image at:
http://farm9.staticflickr.com/8303/7851317670_3a50a8e437.jpg
    Aug 24, 2012 8:54 AM   in reply to Pilaar39
    Inner shape on top - downward inner bevel.
    Outer shape - upward inner bevel.
    You can link the two Shape Layers to make them always stay together.
    Aug 24, 2012 9:25 AM   in reply to Pilaar39
    Two Shape Layers.
    Inner shape:
    Outer shape:
  • Noel Carboni
    Dec 23, 2006
    Aug 24, 2012 9:12 AM   in reply to Pilaar39
    What he's saying is that you have to draw two shapes, one over the other and use Inner Bevel on both.
    Not the ideal solution, but a workaround.
    Bonus question for Conroy (as I am drawing a blank)...  How would you best make the inner part transparent?  I'm thinking maybe group the layers and add an inverted rectangular path as a layer mask on the group...  If only I could remember how to invert a path (I have a headache today).
    -Noel
    Aug 24, 2012 9:16 AM   in reply to Noel Carboni
    Target the Path and change its mode to Subtract.
  • Noel Carboni
    Dec 23, 2006
    Aug 24, 2012 9:38 AM   in reply to Pilaar39
    Thanks to Conroy for getting me to try the tried and true vector path inversion process again, which for some reason I fell down on the first time, here's a possible approach.  It involved drawing three rectangles, and using the innermost one to mask out the center of the shape group.
    Here's the PSD if you'd like to have a look at it in more detail:
    http://Noel.ProDigitalSoftware.com/ForumPosts/BeveledFrame.psd
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Aug 24, 2012 12:23 PM   in reply to Pilaar39
    I just use the little camera icon at the top border of the editor box when posting to upload an image for inline display.  I'm running IE9.
    The thin white line may be the path itself showing, which will not come out in your work product.  That's why it appears in the sample I posted above.  Click on another layer and see if it goes away.
    -Noel
