extracting bridge metadata
Aug 3, 2012 8:22 AM
After adding info to the metadata, such as city, sublocation, state, description, I have to enter all the same data to an MSwroks database that i then import into MSAccess.
I thought maybe there was some way to just transfer data with the same field names and thought of adding more of  Windows Explorer tags.  The date created already is there so I searched the list and added city, and state, camera model, etc.  But then those fields and others were still blank, though filled in Bridge.
.  So I am wondering how such information would get into Explorer to be displayed, if Bridge's categories aren't the same.
IS there any way to export such desired information from all the images in a folder.  I just finished supplying the data to another 800+ images recently shot and don't relish entering it all again into the MSWorks database.
    Aug 3, 2012 11:18 AM   in reply to robirdman1
    You can extract all the required information using the BarredRock script near the end of this thread..
    http://www.ps-scripts.com/bb/viewtopic.php?f=19&t=2365&sid=db5c5a44a97 941756a1991164103a274&start=15
    or you could use ExifTool http://www.sno.phy.queensu.ca/~phil/exiftool/
    Aug 25, 2012 11:30 AM   in reply to robirdman1
    If it's only a few fields this script might do.
    http://www.scriptsrus.talktalk.net/Extract%20Metadata.htm
    Install instructions are on the page and they would apply to the BarredRock script as well. This script will work with CS2 or better (including CS6)
    Aug 26, 2012 3:01 AM   in reply to robirdman1
    I have modified the Extract Metadata script so that it will extract from raw files (NEF,CR2 etc) so please download the zip again for the new version.
    Aug 26, 2012 4:46 AM   in reply to robirdman1
    It works for me, maybe you are using different fields.
    Could you tell me what version of Bridge you are using and what schema(s) and field names you want extracting.
    (See Rawdata in File Info)
    Aug 26, 2012 9:08 AM   in reply to robirdman1
    I have changed the IPTC City and Country to the Photoshop Schema.
    Could you please try this now.
    If you let me know what fields you would like added I will try and add them.
    Aug 27, 2012 9:00 AM   in reply to robirdman1
    I have now added those fields, hope it will be of use to you.
    Aug 27, 2012 11:09 AM   in reply to robirdman1
    I have now altered the state/province to the Photoshop one.
    Glad it may be of use to you.
    Oct 23, 2012 7:04 PM   in reply to Paul Riggott
    Paul,
    I have just used script to extract metadata. Once I found it extracted to the desktop, Great!
    Thanks for that.
    Ian Cleland
