I am using InDesign CS4. But I am having a trouble aligning objects. I know that in illustrator it is possible to align objects to a main object. For example, lets say I have several same square shapes on my page. I can make any one of the squares as the main object for others to get aligned or distributed to.
I wanted to do the same thing in InDesign but was never able to do that. I wonder if it is even possible to do that. InDesign doesn't seem to have that option. But it was such a handy tool.
Can you help me with the trick?
This feature is added to CS6 I believe.
But for prior versions, you can lock one object and then Aligh the objects to the locked object.
http://www.peachpit.com/articles/article.aspx?p=1309259&seqNum=17
Thanks for the replies.
My common sence also suggested me that I should try locking one of the objects. Unfortunately, after I do that and apply align or distribute tool, the program says "Object is locked" and nothing moves. So this trick doesn't work on my CS4. Also I looked up in the Preferences and couldn't find anything about Object Alignment option.
Thanks Peter Spier. I am sorry for the misleading information. You were right about the alignment and distribution tools. On my CS4, the Alignment option works with the locked object, but the Distribue Objects and Distribute with Set Space doesn't work with a locked object. I am trying to use the distribute with a set spacing around "the main object". In other words, it will make my work a lot easier if I first align an object at a certain point on the page and then use two other text frames on both sides of the object with an equal spacing (using the Distribute Spacing tool).
I hope it makes a sence. Thanks.
I think distribute might work if the locked object is on one end (but then you wouldn't need to lock it, would you?), but not if you use spacing. I have some memory of filing a bug on this and it got deferred, so you may be essentially out of luck.
My suggestion for a workaround would be to set some guides so you can reposition, unlock the object, do your distribution, group, and move the group.
I tried it, distribute works only by referncing the space from the leftmost object. So it always distributes to the right side (and all objects has to be unlocked) even with a set spacing. As you suggested, my only option would be set a guide and reposition them manually. But it would have been so much easier if I were able to distribute automatically with the center object as the reference point. Because I have to do hundreds of pages of these things.
Well, the obvious response is it might be time to look at an upgrade. CS4 is getting long in the tooth and CS6 does what you want, and a few more new features, too. Your productivity improvements might pay for the cost of the upgrade, and now is about as good a time to do it as you'll find. When the next version is released you probably won't be eligible for upgrade pricing.
