Confused polygon
Aug 26, 2012 6:11 PM
Tags: #indesign #polygon
I have a polygon in InDesign.  When I stroke it, the "inside" and "outside" are reversed; when I specify align the stroke outside, it appears inside the polygon, and vice versa.  How can I tell InDesign to flip its notion of what is inside and outside for this particularl polygon?
The polygon was created by copying an object from Illustrator.  In Illustrator, the object was created by typing a single character and converting it to outlines.
The ultimate goal is to get separate special effects for the stroke and the fill for the characters.  If I enter the text in InDesign and convert to outlines, I get a variation of the same problem: After the conversion, stroking the outlines means some of the characters are getting stroked inside and some outside.
    Aug 26, 2012 6:42 PM   in reply to OC Photoworx
    I think I'd restore my preferences. It sounds like the corrupted prefs are affecting both Illustrator-created and InDesign-created objects. You can do that this way:
    Troubleshooting 101: Replace, or "trash" your InDesign preferences
    Aug 27, 2012 1:31 AM   in reply to OC Photoworx
    Hi Ted
    Object menu -> Path -> Reverse Path
    It sounds like either the path gets reversed while copying, or it is in fact 'the wrong way around' in one of the programs but the other does not mind.
    Aug 27, 2012 2:12 AM   in reply to OC Photoworx
    @OC Photoworx – you detected one of the main differences in the basic behaviour of InDesign vs. Illustrator concerning composite paths.
    InDesign does it wrong, Illustrator does it right.
    You can test for yourself: take two rectangles, a small one and a bigger one, let them totally overlap, so that you'll punch a hole in the bigger one, if you make them a composite path. Then apply a stroke with the "outside" option and you'll see the difference…
    One thing to add: if you take text and apply a stroke, there is no difference in InDesign vs. Illustrator. The "outside" option yields the same result. The behaviour is as expected. But in the moment you transform text to paths, you see the difference.
    Uwe
    Aug 27, 2012 2:24 AM   in reply to [Jongware]
    @Jongware – at first, I thought "Reverse Path" was the solution, but in my experiments that does not work.
    To illustrate the problem (InDesign only) with text converted to "outlines":
    InDesign composite path of two rectangles:
    (left: align center; right: align outside)
    Illustrator composite path with two rectangles:
    I think the problem arrises due to a bad design decision of the "Composite Path" feature in InDesign.
    Can we consider that as a bug?
    Don't know…
    Uwe
    Aug 27, 2012 8:16 AM   in reply to OC Photoworx
    @OC Photoworx – can you show your screen grab with the "W" much more larger and taken just after you did a "Select All"?
    Maybe you could provide an example somewhere for downloading (IDML format exported from InDesign (CS4 or higher), or INX, if you are on InDesign CS3 or below).
    Did you try what Jongware recommended? Using the command: "Reverse Path"…
    And maybe your "W" is a composite object out of two separate path objects?
    If you are on InDesign CS5 (or above) check for that in the Layers Palette, where all objects of the current spread are listed.
    Uwe
    Aug 27, 2012 11:52 PM   in reply to OC Photoworx
    @OC Photoworx – sorry, but I cannot reproduce that case…
    On what exact version of InDesign and OS are you?
    I tried with:
    InDesign CS5 7.0.4.553 German
    Mac OS X 10.6.8
    To get the exact version of InDesign hold the cmd-key (when on Mac) and choose "About InDesign".
    Uwe
    Aug 28, 2012 3:38 AM   in reply to OC Photoworx
    OC Photoworx wrote:
    I have created a procedure which demonstrates the behavior in a repeatable manner.  There is probably a simpler example, but this is as simple as I have found so far.  (I have no idea whether any of the specific details (like margin sizes, or regularity of the guides) play significant roles.)  I'm hoping Adobe monitors the forums and someone in the hallowed halls will take the time to follow up on this.
    Instead of hoping someone from Adobe will see this thread, please file a real bug report at Adobe - Feature Request/Bug Report Form outlining your proceedure.
    Aug 28, 2012 9:13 AM   in reply to OC Photoworx
    I get the same thing when working around the shape clockwise (and curiously I get  a miter problem on one spot, too), but reversing the path DOES shift it back to the outside. When working counter-clockwise the stroke aligns to waht will be the inside until the path is closed, then it shifts to the outside. Again, reversing the path switches the stroke here.
    Windows 7
    Aug 28, 2012 10:59 AM   in reply to OC Photoworx
    Have you tried using the scissor tool to cut the path, then rejoin it (or leave it open)?
    Aug 28, 2012 12:34 PM   in reply to OC Photoworx
    @OC Photoworx – ok.
    With tracing the "W" image with the pen tool (clockwise) I can reproduce the issue. Just before closing the path the appearance of the stroke is like I want ("outside"); after closing the path the appearance changes to "inside".
    And another thing, too: when moving the last point before the starting point to the left, the stroke appearance suddenly will change from "inside" to "outside". THAT is really strange!
    It changes in the moment the point moves to the left of the imaginery straight line between the first point and the point before the last point:
    Not moving the path point:
    Moving the point a bit to the left, NOT crossing the line:
    After crossing the line:
    Uwe
    Aug 28, 2012 11:33 PM   in reply to Laubender
    And what will happen, if you have a stroke "outside" in Illustrator and copy that path over to InDesign?
    The stroke will be transformed into a fill:
    Object in Illustrator:
    Copy/Paste result in InDesign:
    Uwe
