Hi All,
I've created some web graphics in InDesign CS5, copy and paste into photoshop and the RGB values change. Not greatly, but they do not match exactly.
My colorspace is synced through Bridge, in sRGB mode in both InDesign and Photoshop.
Any thoughts why they would be different? Thanks.
Mac OS X 10.6.8
Thanks Steve. Just exported and 2 of the 3 swatches matched what I had spec'd in InDesign. The other was +1 off on all. Closer, but still doesn't make sense why it doesn't stay consistent. Luckily, in this case, it's doesn't need to be exact. Just trying to determine what the hex values are for the color palette I had created in InDesign.
Syncing matches up the Color Setting's Working Spaces, but not necessarily the document assignments. Did you make sure both the ID and PS documents have the same RGB assignments (Edit>Assign Profiles...)?
As long as the doc assignments match I'm not seeing a problem in CS6—both the numbers and previews are correct.
That’s because exporting as print PDF converts RGB to CMYK
The PDF/X-4 preset would work because it doesn't allow color conversions.
I don't see any problem cutting and pasting from ID. The ID objects come into Photoshop as Vector Smart Objects, and as long as the Photoshop destination color space and assignment matches the copied object, it pastes unchanged
Also, when you check the ID and PS document assignments make sure you are assigning the same sRGB profile. sRGB is slightly different than sRGB EC61966-2.1 (RGB in the North American Web/internet preset)
@Rob, Color profiles synced up through Bridge. Both RGB set to sRGB EC61966-2.1.
Bridge Snycing doesn't sync document profiles, just the current application Working Spaces. So, if you made an ID document last week with North American Web it will have the sRGB EC61966-2.1 profile assigned. If you then Sync to a color setting with sRGB today, the doc you made last week doesn't change to sRGB—it will still be sRGB EC61966-2.1.
You have to use Edit>Assign Profiles... to be assured of a match, not Bridge
So, here I Sync to North American Web in Bridge, which Syncs the CS applications not individual documents:
And that updates my ID Color Settings:
But not an existing document. If I check the assigned profile of a document created with the North American Prepress preset, the RGB profile is AdobeRGB not the sRGB EC61966-2.1 Working Space.
It's the assigned profile that's used when you cut the object, not the Working Space. If I cut the green square and paste it into an sRGB PS document it will change even though my apps are sync'd:
Thanks Rob, very familiar with the color settings,
I checked a number of RGB colors in both CS6 and CS3 and can't replicate your problem.
Whether you're Color Settings are Sync'd or not has no effect on document colors matching (unless the documents have no profiles assigned) that's why I brought up checking document assignments.
Can you give an example of an RGB mix that's not working for you?
I'll have to pull up the colors at work tomorrow to see. Strange that it works fine for you, yet i just tried a couple of colors here at home. I created 2 random colors, direct copy from InDesign, pasted into photoshop and 1 square was exact numbers, the other was off by 1 in all 3.
I did just notice in your Color Settings for RGB that Convert to Working Space is chosen and Preserve Numbers is on for CMYK. I know my settings are both set to Preserve. Do you think this could be the reason?
You're showing the wrong dialog. You have to check Edit>Assign Profiles... in both apps (Syncing via Bridge won't change these settings).
In ID:
In PS:
It may be that your existing assignments match, but they are not set in Color Settings.
I did just notice in your Color Settings for RGB that Convert to Working Space is chosen.
Setting the RGB policy to Convert and checking Ask When Opening would allow you to force a profile reassignment when you open an existing document with a conflicting profile. It would also change the document RGB numbers if that matters.
