MUSE upgrade fails to install. I'm a Creative Cloud subscriber and have successfully installed all available apps. It's not me or my system. The problem is with the upgrade.
Hi JQuentin,
I would ensure everything is closed when attempting to install the update. Are you installed the update by just launching Muse and following the prompts?
Maybe uninstall it via:
And then try reinstalling it through the Adobe Application Manager.
-Dave
I have done everything possible several times. I even uninstalled the original MUSE that I had already installed successfully. Now I don't have any version of Muse. I've also tried reinstalling Muse from within my Creative Cloud Account, assuming that I was not recognized as a legitimate subscriber. Install Failed. I've uninstalled Muse using Control Panel. I've rebooted the computer (i7 64-bit Windows 7) Install Fails with the highly instructive Error DW050: Adobe Muse:Install Failed. Your package does NOT INSTALL. Are there any others that are having this problem?
David__B <forums@adobe.com> wrote:
David__B http://forums.adobe.com/people/David__B created the discussion
"Re: Muse upgrade fails to install"
To view the discussion, visit: http://forums.adobe.com/message/4646437#4646437
original
version of
Same problems. Update failed and after uninstall of Muse trying to reinstall is also unsuccesful.
Two months ago I also had problems with Muse, The workaround i used then doesn't help me now.
Perhaps Adobe has version problems with Muse and Air that also had a recent (3.4) update.
Or a problem with the new flash version and Muse.
Anyway, the reason I signed up for Creative cloud i.e. Muse doesn't seem to be a good choice since Muse sucks now it's in the production.
with the Beta had I no problems at all.
Windows event viewer (Win XP) describes the problem after the failed update as well as after the failed reinstall as:
'Faulting application adobe muse.exe, version 0.0.0.0, faulting module fontsfre.dll, version 0.0.0.0, fault address 0x00010b78.'
Best,
Ysbrand van der Veen
P.S. To see how the Muse uninstall problem relates (that's what it in essence is) to the other apps in Creative Cloud, I unstalled all the other Creative Cloud apps I had installed.
Uninstalling them changed the Status in AAW (adobe app mgr) from <installed> to <install> like it should be with only one exeption that is Adobe Muse.
Even manually deleting the prefetch files for Muse and all other remains of Muse I could find with Windows search on my c: drive didn't help me out.
Uninstalling Air (though needed by other apps) didn't solve the problem as well of Muse having the in this case hateful status of installed although uninstalled.
ymvdveen, there is a bug in Muse 2.0 that results in a crash shortly after launch of Muse for some users on Windows XP. For some users the crash occurs on every launch. Others are able to run without encountering it. We're working on an update that would go live by the end of next week. Until then the only option for XP users that encounter this crash is to revert to using Muse 1.1.
To revert to Muse 1.1:
1) Remove Adobe Muse using the Windows Control Panel.
2) Install Muse 1.1 from the following link <http://labsdownload.adobe.com/pub/adobemuse/builds/muse_1-1_update_win .exe>.
When Muse 1.1 is launched it will ask you to update to 2.0. Until late next week when 2.x is available, you'll need to choose "Later".
ymvdveen, per my message above you'll need to revert to Muse 1.1 using the link provided above. I'd actually recommend using this link without first getting into a state where the AAM believes Muse is uninstalled, since using the installer at this link won't update the status of the "installed" information for AAM.
The crash you posted earlier
indicates a Windows XP-specific crash we're working of a fix for that should be part of an update out late next week.
Muse 1.1 runs smoothly, txs.
The administrative system of the Creative cloud needs improvement. Although my Muse 1.1. is registered (just checked) I received an email this evening (european time and about 26 hours after re-registration of Muse) 'Welcome to your Adobe Muse trial — tips and tutorials inside'.
Best, Ysbrand
Netherlands
