How do i update Installed AIR Applications? // General Questions
Aug 27, 2012 6:24 AM
Tags: #air #install #update #upgrade #system #installation #enterprise #silent #salesforce #sccm #windows7x64 #arh #arh_tool #chatter #logfiles #sfdc
first of all, i'm completly new to AIR. However, i made my way through your product documentation and i'm now able to deploy AIR and a AIR Application (SFDC Chatter) and register it.
Works fine so far, but some questions:
- How can i update installed AIR applications? If i just try to re-install it, the installer will fail with exit code "9"
     -> How can i update them directly? If this is not possible
      -> How can i uninstall AIR applications in a large enterprise environment?
- Where is the ARH Tool that is described in your product documentation?
- When installing AIR as SYSTEM User (I'm using SCCM) where is the logfile?
- Do you recommend updating AIR on a regular base? Are "older" applications compatible with newer AIR Versions?
Thanks for your replies!
Ben
