Robin Kluth
[FP 11.4 & FF 14.0.1] Firefox hang on every page with flash-content
Aug 27, 2012 12:41 AM
Tags: #flash #windows #firefox #freeze #hang #x32 #11.4 #14.0.1
Hi at all
I have a problem with the new Flash Player, let me explain it:
We have a windows-domain with software distribution via GPO.
Since update to 11.4 via the msi package (11.3 was previously installed) we have in the meanwhile 3 PCs (all Win7 x32 with FF 14.0.1 and Flash 11.4) with this problem:
- While loading a page with Flash content, the Firefox simply freezes and have to be killed together with plugin-container in order to work again.
If this happens, ff and plugin-container have 0% cpu-usage. It freezes and does nothing...
If I remove Flash: Web-pages are working, but without flash.
What I've tried:
  • reinstall using flash-uninstaller
  • Using "normal" end-user web-installer
  • Uninstall via Uninstaller and tried 11.3 again
  • reinstall Firefox, both 14 and 13
Nothing helped to bring Flash-support back.
This happens only on FF, Internet Explorer is working fine...
Can someone give me a hint?
    Aug 27, 2012 3:11 AM   in reply to Robin Kluth
    Sorry, not many ideas about this...
    What I would try if I encountered this problem: try on one of the affected machines
    Does it work better after that?
  • Chris Campbell
    May 4, 2010
    Aug 27, 2012 6:19 PM   in reply to Pat Willener
    If Pat's suggestions don't work, could you try temporarily disabling protected mode (see the bottom of the faq below) to see if that makes a difference?
    How do I troubleshoot Flash Player's protected mode for Firefox?
  • Chris Campbell
    May 4, 2010
    Sep 6, 2012 2:40 PM   in reply to Robin Kluth
    Robin, have you tried disabling protected mode using the instructions in the FAQ I posted above?
  • Chris Campbell
    May 4, 2010
    Sep 12, 2012 11:14 AM   in reply to Robin Kluth
    The key here will be to determine what is different between the machines that work and those that hang.  Of all the systems that fail, they are all Windows 7 32bit?  Do you have any 32bit systems that don't fail?  What about hardware, are there similarities here?  Attached devices/drivers?  Software that is running at the time?  Maybe try booting Windows in safe mode to see if it still hangs?
    We're definitely interested in what's going on.  I'll ask our security and Mozilla folks to see if they have additional clues.
