How to batch process multiple layers to jpegs
Aug 28, 2012 9:39 AM
I have over 500 layers of different texts over a simple background image. I need to move through each one of these layers, making only one and the background visible, then doing the same for the next, and saving each out as a separate .jpeg. I know how to batch process the jpegs giving each a different filename, but how do I move through the layers?
Thanks.
    Aug 28, 2012 11:12 AM   in reply to rlinsurf1
    Have you looked at using File>Scripts>Export Layers to Files?
    Aug 28, 2012 11:56 AM   in reply to rlinsurf1
    Export Layers to Files will not select the background layer along with each layer but this script will..
    http://www.scriptsrus.talktalk.net/Layer%20Saver.htm
    Aug 28, 2012 12:53 PM   in reply to rlinsurf1
    There would be a problem with your set up, to get it to work you would have to create a snapshot,  lose the groups/layersSets and have all layers visible. You can then save each layer with the background then revert back to the snapshot.
