Problems installing with Ubuntu 12.04
Aug 28, 2012 12:53 PM
Tags: #flash #ubuntu
When I try to install Flash Player for Ubuntu it launches the Ubuntu Software Center which apparently is supposed to contain the app to install Flash. In my case though the Software Center loads and says it can't find the package. When I do a search in the Software Center I cannot find Adobe Flash Player.
Tons of other software is available in the Software Center and I'm live on the Internet.
I have both Firefox and Chromium installed for browsers and have tried from both.
How do I get this installed?
    Aug 29, 2012 11:29 AM   in reply to osubsu
    Hello,
    Welcome to Adobe Forums.
    You can follow these steps :
    1) Login with "root" user on your Ubuntu 12.04
    2) Launch "Terminal" (Keyboard Shortcut : Ctrl +Alt +T)
    3) Type this command and hit Enter : sudo apt-get install flashplugin-installer
    4) Launch Firefox and check do you have Flash Player (http://www.adobe.com/software/flash/about/)
    Vikram
    Aug 29, 2012 11:55 AM   in reply to osubsu
    Hello,
    Try these 2 command as well on Terminal:
    1st : sudo apt-get update
    2nd : sudo apt-get install adobe-flashplugin
    Vikram
    Aug 29, 2012 1:21 PM   in reply to osubsu
    Hello,
    Does this command works ?
    sudo apt-get install flashplugin-nonfree
    Vikram
    Aug 29, 2012 3:51 PM   in reply to osubsu
    Hello,
    There is a procedure of Manual Installation of Adobe Flash Player on Ubuntu, follow these steps :
    1. Open http://get.adobe.com/flashplayer/otherversions/
    2. Choose Linux 32-bit on Step 1
    3. Choose Flash Player 11.2 (tar.gz) on Step 2, download the file
    4. Once download is complete, right click on the flie (tar.gz) and click on "Extract here"
    5. Launch Terminal (Keyboard Shortcut : Ctrl+Alt+T)
    6. Go to that location where you extracted the file
    7. Run this command : sudo mv libflashplayer.so \/usr/lib/firefox-addons/plugins
    8. Launch Mozilla Firefox and check do you have Adobe Flash Player
    I tested this and it worked
    Vikram
    Aug 30, 2012 9:20 AM   in reply to osubsu
    Hello,
    Just want to confirm, Shockwave Plugin is "enabled".
    What message do you see in Firefox on this page : http://www.adobe.com/software/flash/about
    Vikram
    Aug 31, 2012 3:52 AM   in reply to osubsu
    Please type the following in Firefox: about:plugins
    Do you see Flash Player there but disabled?
    If not, could you please copy libflashplayer.so to /usr/lib/firefox/plugins directory?
    Sunil
