DandyDahlia 112 posts
Apr 12, 2012
Updating Customers (import) errors??
Jul 31, 2012 8:01 PM
Tags: #support #bug_report #contacts #business_catalyst #crm #business_catalyst_error
We have done this before with no dramas but today on updating our contacts in mass (5975)  it's just not working.
It keeps coming up saying "
Error
  ERROR: [ The username is already in use. (123gifts).]. Import process failed on record: [2] Please ensure 1) mandatory columns are present, 2) all products have Product Codes defined, which should be unique (if importing products)
But this is the username they already have. (They have the same email too). We have only updated other fields. So I'm 100% confident our data is fine. Username is a mandatory field too so can't be left blank.
We have followed the instructions BC has:
Mandatory Fields that must be imported to avoid wiping out an existing value:
  • Title
  • First name
  • Last name
  • DOB
  • Username
  • Password (ignore as doesn't update anymore)
  • Email
  • Customer Type
  • Lead Source Type
  • Industry Type
  • Rating Type
Has anyone seen this before or know how to fix it?
Thank you
    Aug 28, 2012 10:50 PM   in reply to DandyDahlia
    Hey DD, I've been having this problem also, it was supposed to be fixed on the latest update but I believe it's still happening.
    See http://forums.adobe.com/message/4652837#4652837
    Aug 28, 2012 11:50 PM   in reply to DandyDahlia
    Hey DD,
    Thanks for your reply, we are using the ID field, this isn't the problem though. It's the dreaded username bug ( Reported Bug # 3313655 ).
    I like your creative idea of uploading without usernames and then again with usernames but these are drastic measures and I'm hoping BC will fix the problem before I have to use your method, but if we get desperate we might have to resort to this.
    Cheers,
    Steve
  • Liam Dilley
    Feb 28, 2012
    Aug 29, 2012 12:36 AM   in reply to Steve @ Lightplay
    Hi Steve, I see BC got back to you in your other thread and Cristian mentioned you had duplicate contacts in your spreadsheet.
    Aug 29, 2012 12:57 AM   in reply to Liam Dilley
    Hi Liam, yes there were duplicates, support kindly removed them and were able to upload successfully, however when I tried with the same file but also adding to the Secure Zone it failed at the same point, I checked the import and the system and there are no duplicates of this username. The plot thickens!
