crystoral@aol.com
pdf printer
May 21, 2012 11:28 AM
installing a pdf printer
    May 21, 2012 11:53 AM   in reply to crystoral@aol.com
    And what exactly do you mean? You need to be more specific.
    Mylenium
    May 21, 2012 3:14 PM   in reply to Mylenium
    Moving this discussion to the Printing & Prepress forum within the Acrobat forums.
    May 23, 2012 9:18 PM   in reply to crystoral@aol.com
    A little tongue in cheek; nevertheless -
    Install Adobe Acrobat.
    Be well...
    Aug 29, 2012 7:04 AM   in reply to CtDave
    I'm looking for an answer to installing a PDF printer in Mac OS X 10.7.3. I've installed Adobe Acrobat. That doesn't help me when I want to print from Quark or InDesign, or any other application, to a postscript file. How do install in Mac OS X 10.7.3 what used to be known in previous Mac OS's as a printer description file, or printer driver, for printing to .ps files?
    Aug 29, 2012 7:55 AM   in reply to mpkoenig3
    You cannot install such a PostScript printer driver instance under MacOS anymore. It is an operating system restriction.
    For Adobe applications, you really should never be producing PDF via distillation of PostScript anyway. Simply export PDF from InDesign or save PDF from Illustrator or Photoshop. This yields much higher quality PDF than you would ever achieve via the distillation of PostScript route.
    For other applications assuming you have Acrobat Pro installed, you can get Adobe quality PDF by simply going to the print dialog and from the lower left corner dropdown box, choose Save as Adobe PDF.
              - Dov
    Aug 29, 2012 4:07 PM   in reply to Dov Isaacs
    Dov,
    Thanks for your reply. Unfortunately, your answer doesn’t help. Yes, I have Acrobat Pro installed. I don’t have a printer installed. I need to create PDFs for everything. But when I’m other applications, like QuarkXPress - the main program I use, there isn't a dropdown box in the lower left corner. It demands that I choose a printer driver so that it can set up its print parameters. In the absence of an Adobe PDF printer driver (my preference), it defaults to “Generic BW” or “Generic color” or some other printer that I don’t have. If I choose from any of the default choices, I don’t have the control that need for setting the page size and printable area (it’s part of those printer’s default settings, which I can’t change). If I can’t install a PostScript printer driver, which default printer driver should I choose to make the best PDFs (i.e. where I can set custom page sizes, and not deal with printable areas)?
    Also, I’ve always produced my PDFs via distillation of PostScript. It gives me the most control in determining the qulity and file size of my PDFs. Why do you say I should NEVER do that?
    Aug 29, 2012 5:25 PM   in reply to mpkoenig3
    For Adobe applications, the PostScript generated for printing is optimized for printing, not for creation of PDF. The needs for printing, especially in terms of how fonts are output in the PostScript stream, are very different than the needs for PDF. Furthermore, in creating PDF via distillation of PostScript, you end up with PDF with no live transparency and no color management. PostScript doesn't support live transparency or ICC color management. All transparency in your InDesign, Illustrator, and/or Photoshop files is flattened at some resolution (whatever parameters you specify). Your resultant PDF is effectively now device resolution and color space dependent. Text quality may suffer if it was involved in flattening and may not be searchable or capable fo being edited with text touch-up. Direct PDF creation from these applications gives you full choice of the same joboptions and more (including support for PDF/X-4) than you have with Distiller!!! For InDesign-exported PDF, recent versions of InDesign provide signficant optimization in terms of repeated use of graphical objects in cutting the size of the resultant PDF files. We know of no good reason other than perhaps traditions that should be replaced for continuing to create PDF via distillation of PostScript from Adobe applications either on Macintosh or on Windows.
    Unfortunately, I obviously cannot speak for Quark. They do provide their own PDF creation capability with their product for which I have no idea how good, bad, or indifferent it may be.
    For other applications, the method I described in my previous postings should work (I know it works with Acrobat Pro and any and all Microsoft and Apple applications on MacOS).
            - Dov
    Nov 22, 2012 4:05 AM   in reply to crystoral@aol.com
    OK, but what if I create a Poster at A4 (for file size) and I want to create a PDF that is A1 (so increase it by 200%). How do I do that now?
    Indesign CS6
    Nov 22, 2012 4:09 AM   in reply to pete006
    Scale in InDesign. Don't try to do it later, it's something to do at the design stage. Don't abandon PDF export just because you want to do something differently.
    (Prepress pros might have plug-ins that can scale PDFs, but designers don't need to go there)
    Nov 27, 2012 9:30 AM   in reply to crystoral@aol.com
    before, download one driver ppd from sceen or agfa (www.screen.co.jp - www.agfagraphics.com ) postscript after you must plce this driver into folder ppd of system.
    when you need to print specify the folder that it contain the PPD.
    Apr 16, 2013 8:05 AM   in reply to crystoral@aol.com
    Hi all,
    I think we have the same problem: acrobat installed but when you Export a file you still see the default Indesign limited PDF dialog.
    The solution for me was to go to menu File > Adobe PDF presets > [select on here]
    Once selected just give a name to the file and save a PDF.
    Now the next time you Export via File > Export, it will remember the last option (which is indeed, the PDF printing dialog)
    I hope that helped anhgone with the same problem.
    regards,
    Apr 17, 2013 12:12 AM   in reply to antron
    Actually, installing Acrobat has NO EFFECT on what InDesign export is capable of or how it works. It has the same options before and after, and does the same job. Acrobat is simply not involved with InDesign PDF Export before or after. (It might add named presets, but not capabilities).
    Export is strongly recommended over printing to PDF for InDesign, as has been noted.
