Q. for T. Knoll, E. Chan or J. Schewe
Aug 29, 2012 2:22 AM
Kindly refresh my memor on the subject of noise reduction applied to raw files (only) in ACR not being reflected in thumbnails and/or preview panel in Bridge.
I posted this question originally in the Bridge forum in a thread that contains relevant screen shots.  Here's the link to that thread:
http://forums.adobe.com/thread/1056532?tstart=0
Here's the text of the original post there:
A major senior moment leads me to ask for help in refreshing my memory regarding the Noise Reduction applied in ACR not being reflected in the Preview panel within Bridge after clicking the Done button in ACR.
My recollection was that Noise Reduction and Sharpening applied to a raw image in ACR are not reflected, or at least not fully reflected in the Preview panel nor in the thumbnail in the Bridge Contents panel.
I've been trying to do a forum search for a post where one of the high gurus (Knoll, Chan or Schewe?) confirmed this fact in this forum, but due to the aforementioned major senior moment, I've been unable to find the right keywords for my search, so I've come up blank.
Thanks in advance.
If any member of the ATM team or Jeff Schewe cares to comment, I'd be much obliged.
    Aug 29, 2012 6:25 AM   in reply to station_two
    Don't know about the original post, but you aroused my curiosity.  Opened a raw file from Bridge (ACR 7.2RC), applied very crunchy sharpening, and then clicked Done.  Back in bridge using the loupe set to 100%, the preview clearly showed the excessive sharpening.  Nothing apparent in the thumbnail or in the preview without the loupe.  Preview set to "Always high quality".
    Aug 29, 2012 8:35 AM   in reply to RASouthworth
    Continuing to experiment, cropped a small section of the image so that the preview in Bridge would be at 100%,  No sharpening visible in preview, and also the loupe no longer shows sharpening.  Seems somewhat inconsistent.
    Aug 29, 2012 11:02 AM   in reply to station_two
    Yes, except that when I create a small cropped area such that I obtain a 100% preview, the loupe bottoms out at 200% and it's hard to determine what's going on.  BTW I repeated the experiment for noise reduction, and after applying very heavy NR in ACR and cropping a small portion, the 100% Bridge preview did reflect the NR.  So my first guess is NR gets thru to the preview and sharpening doesn't.
    Aug 29, 2012 4:08 PM   in reply to station_two
    Is ACR set to Sharpen For None and this affects the preview sharpening?
    Aug 30, 2012 6:34 AM   in reply to station_two
    Bridge would be using ACR w/o a UI to create the high-quality previews.
    I was asking the question about the situation where RASouth said that NR seemed to be applied whereas Sharpening was not, and station_two says that neither was.  If the same version of Bridge and ACR are being discussed then something must be different locally.  Perhaps it is just the size of the raw file that is different.  If both RASouth and station_two have Sharpen For All Images set then this would not be the difference.
    I wondered if a misguided Bridge programmer had taken the Sharpen For Previews vs All to mean Sharpen Previews Yes/No when they created the render-recipe to pass to Bridge when creating previews.
    It seems reasonable that Bridge might be doing different things between Preview and Loupe mode, but not that its treatment of raw files is inconsistent between one system and the next.
    If it helps the initial question of there being a senior moment about how NR and Sharpening worked previous compared to know, I remember that in Lightroom the handling of whether LR’s preview image shows sharpening and NR did change in a recent version to show more of the sharpening/NR at smaller than 100% sizes,  so maybe ACR’s policies did change as well.  It also used to be in LR that different sized RAWs showed or didn’t show the sharpening/NR—it was a camera-by-camera or size-by-size decision, which could explain the inconsistency between two different users’ experiences, unless the same RAW file is being experimented with.
    Aug 30, 2012 6:53 AM   in reply to ssprengel
    Just to make sure, I shot a very noisy image and examined in ACR 7.2RC.
    Given that I cropped the image so that the Bridge preview was a 100% view (i.e., each pixel in the image mapped to one pixel on the monitor), sharpening did NOT carry over to the preview,  but noise reduction did.  I did no further loupe examinations, only preview.
    I have ACR preferences set with "Apply sharpening to" :  "All images".
    Aug 30, 2012 9:45 AM   in reply to station_two
    So your current theory is that the difference in Preview NR or not is whether the pixels are 1:1 or not.  I forget if you did this, already, but if you perform the small-enough-for-1:1 crop on your example in the other thread, do you get NR or not?
    Another reason for the difference could be that the amount of noise in your image is there because of the extreme exposure increase—maybe the underlying ISO is actually still rather low and ACR is using the ISO as a threshold to decide if the preview has NR applied or not, rather than the actual adjusted-image noise which would be much harder to characterize correctly.
