Help with Script
Aug 29, 2012 9:03 AM
Hi everyone!
Here is my problem..
Department field is a required field into a hidden subform (form1.Page1.REPLACEMENT_SUB).
The problem it is when I click the email button it's ask me to fill in
the above field(Department)!
I have a DDList with two item (Employee Name,Department).
The Department field becomes available(visible) if I select Department from DDL.
Please help!
Here is my variable:
function Ex1ValidFields()
   var bRtn = false;
   var aErrMsg = [];
   var rgEmpty = /^\s*$/;
if((form1.Page1.Section_A.EmployeeName.rawValue == null) || rgEmpty.test(form1.Page1.Section_A.EmployeeName.rawValue))
      aErrMsg.push("Employee Name");
if(( form1.Page1.REPLACEMENT_SUB.Department.rawValue == null) || rgEmpty.test(form1.Page1.REPLACEMENT_SUB.Department.rawValue))
      aErrMsg.push("Department Name");
if(aErrMsg.length == 0)
      bRtn = true;
      else
      app.alert("One or more required fields have not been filled out:\n\n   * " + aErrMsg.join("\n   * "),4);;
  1. xfa.host.currentPage = 0;
   return bRtn;
For email button on click event I have the script below:
if(Init.Ex1ValidFields())
var myDoc = event.target;
var address = "aaa@bbb.org";
var sub = "Staffing Req - ";
var Sender =(form1.Page1.Section_A.EmployeeInfo.Row1.PositionTitle.rawValue);
var msgBody = "See my Form attached.\n\nThank You!";
  1. myDoc.mailDoc({ bUI: false,
cTo: address,
cSubject: sub + Sender,
cMsg: msgBody + "\n\nRegards\n",
cSubmitAs: "PDF"});
