I am trying to compile a WebHelp project using the RHCL command. I have RoboHelp HTML 9.0.2.271, running on Windows 7, and the project compiles fine from within the GUI. However, although the first part of the compilation (processing, updating, etc.) works using RHCL, the part where the WebHelp 5.50 template is applied is full of errors. For example:
Template Error: can not resolve macro: WH_LNG_LoadingData
..Template Error: can not resolve macro: WH_LNG_MergeError1
Template Error: can not resolve macro: WH_LNG_MergeError2
Template Error: can not resolve macro: WH_LNG_JS_alert_ProjectLoadingFail
..Template Error: can not resolve macro: WH_LNG_PreTooltip in D:\CUACV9\Administ
rator WebHelp\!SSL!\WebHelp\whtopic.js
Template Error: can not resolve macro: WH_LNG_NextTooltip in D:\CUACV9\Administr
Template Error: can not resolve macro: WH_LNG_Show_Navigation_Component in D:\CU
ACV9\Administrator WebHelp\!SSL!\WebHelp\whtopic.js
Template Error: can not resolve macro: WH_LNG_Hide_Navigation_Component in D:\CU
Template Error: can not resolve macro: WH_LNG_SyncTocTooltip in D:\CUACV9\Admini
If I delete my !Language! folder, I get what looks like the same errors within the RoboHelp GUI.
I have tried a couple of the "solutions" that I found online: copying RoboHHRE.lng from the relevant !Language! subfolder to the project folder, and changing the project to a different language and back to the one I want to use. But all to no avail.
Does anyone know of a solution, please.
Many thanks!
Macro errors are usually caused be permissions issues. There is a Command Line Generation article by Bill Albing hosted on my site.
This thread seems to have the same errors at the end with no further response.
http://adobe.hosted.jivesoftware.com/message/3757759?tstart=0
I'll ping a couple of people to see if they can help.
Is your output WebHelp or WebHelp Pro?
Hi folks. I don't have an answer, but I helped someone last year with something similar. I'm not sure if it was related to using the RHCL, an LNG file problem, or in anyway related to RoboHelp Server. But I'll ping the person at Adobe that I had worked with previously and see if we can resolve this.
Ian, have you reported this to Adobe Technical Support? If so, it would help if you could send me any case numbers or contacts to my email (see my profile). Also, as Peter mentions, we need to know to what kind of server the RHCL is trying to communicate with. Were you ever able to publish from the RH client to your web server in the conventional way? This would help validate that the permissions from your machine are valid. I'm a networking novice, but it does have the look of a permission thing.
John Daigle
Adobe Certified RoboHelp and Captivate Instructor
Evergreen, Colorado
HI John,
Thanks for your mail.
No, I have not reported this to Adobe Technical Support.
I am producing WebHelp with both source and output on my laptop. There is no separate web server involved in the process.
Everything works fine (and has always worked fine) from the RH GUI, although it appears (I haven't looked in detail) that I can replicate the problem there by deleting !Language!
In the past I have manually generated the help and then copied the relevant folders to another machine.
I have just started investigating RHCL because my development team would like to be able to automate Help creation so that it is part of the s/w build process.
Regards
Ian
HI
even in older version of RoboHelp we do get such an error if we do not generate WebHelp output from RoboHelp UI even once and directly try to generate from RHCL.
for any new project at least generate WebHelp once and try RHCL after that, please update if you still get such errors.
Hope this will help
Ashish
If you've got a spare machine kicking around, it might be worth it to pull down the trial version & play with it using a copy of your project to see how it performs.
Regarding the upgrade cost - our organization bought a 2 year upgrade plan (which includes bronze support thrown in too) for less than that I think.
HI Ian,
Can you please confirm if you or anyone else has done any changes to the files kept in "whxdata" folder in your RoboHelp install folder or by any change you have updated the lng xml file of your project?
by the way by update I just meant the RoboHelp 9 updates and not upgrading to RoboHelp10.
but I would be tempted to talk about the new features like multiscreen output - it can produces highly customizable outputs which can be viewed on any modern device like tablets or smart phones.
Regards
Ashish
Hi Ashish,
Thanks for your help!
No, no one has touched the files in the whxdata folder (I didn't even know of it's existence until I searched for it following your mail).
As for the RoboHHRE.lng file, I have tried the solutions from http://forums.adobe.com/message/2279210, which involved placing a copy of the file in the project folder and adding the following line to the file:
<element name="FtsMaxResult" value="Search results per page" />
The current situation is that both files exist and both include that line.
I have not been able to compile from RHCL in any configuration.
Regards
Ian
Hi!
Good news! A colleague of mine has solved this problem!
The key is to use the full path name of the RHCL command.
I was using
rhcl "D:\XYZ\Administrator WebHelp\WebAdmin.xpj" -l WebHelp
but this generated the errors I reported.
However, the following works perfectly:
"C:\Program Files (x86)\Adobe\Adobe RoboHelp 9\RoboHTML\rhcl" "D:\XYZ\Administrator WebHelp\WebAdmin.xpj" -l WebHelp
The quotes are needed because of the spaces in the path to RHCL.
