Is it possible to find the value of the corner radius of the rounded corners for a rectangle that was created with the Rounded Rectangle Tool?
This if for CS4.
Thanks.
Hello Just_A_Mac_Guy,
Thanks for the tip. I did try it with a new box created with the Rounded Rectangle Tool and your method gave me the correct corner radius (H=W=corner radius I entered at creation). However, with the box I intended to do the measurements with in the first place, I obtain two slightly different readings for H and W.
I suspect, as Jacob does, that the rounded corner box was scaled unevenly so that the width does not equal the height. No way to tell the original radius, I am afraid, so use which ever one is more pleasing. You can also pull a round circular box as a trial. Then use half the diametre.
I had mentioned rotation because if the arc was rotated, the demensions would not give the true radius.
Hello.
I don't believe there had been any modifications made to the box, except perhaps even scaling (H & W). However, I am not sure. The difference between H and W is around 0.001". In any case, Just_A_Mac_Guy's tip is very useful. It's probably wiser that I use the Rounded Corners FX next time!
Thanks.
sPretzel,
That is too much to be just the inherent accuracy (which is no more than about 0.001 pt), so something must have been done/gone awry.
You could also use the Effect>Convert to Shape>Rounded Rectangle (setting the Extra width/Height to 0). That would ensure that no change is made to the corner radius. You may Object>Expand Appearance at any time, to see the radius or to enable rotation and so on.
