Merging Groups Cropping Problem CS6
Jun 13, 2012 8:53 AM
Tags: #photoshop #merge #layers #cs6 #cropping
When merging groups in Photoshop CS6 (Command-E), the images are now being cropped to the document edge. I need to retain the image data for repositioning/sizing. This was not default behavior in previous versions and I can't find an option to change it.
    Jun 13, 2012 11:07 AM   in reply to cwolsen
    Yeah, huh. You're right. I wonder if that was an intentional change in CS6...
    If you reveal the content of the Group, target its layers, then merge, you'll retain the outside data.
    Jun 13, 2012 1:31 PM   in reply to cwolsen
    Yeah... maybe that should be bugged. Don't know why Merging a Group should have changed.
    Aug 30, 2012 11:46 AM   in reply to cwolsen
    Yep, just starting using CS6 and this is annoying.  I like to group to flatten and then make that layer a smart object because I don't need the other layers but I want the new layer to retain nondestructive sizing.  Yes you can get around it but why would you change this?
    Dec 17, 2012 5:55 PM   in reply to cwolsen
    Pls fix this bug, quite annoying.
    Dec 19, 2012 8:43 AM   in reply to cwolsen
    Hooray! Update your PS this issue appears to be fixed. Although, upon updating I seem to be encountering errors with application manager.
    Dec 19, 2012 1:36 PM   in reply to iamwickedtall1
    Which update are you referring to for photoshop cs6?
    Dec 19, 2012 4:47 PM   in reply to cwolsen
    I just upgraded to: Adobe Photoshop Version: 13.0.2 (13.0.2 20121126.r.23 2012/11/26:21:00:00) x64
