Error generating a Folio
Aug 31, 2012 12:06 AM
Tags: #error #indesign #folio #cs6
Hallo everybody,
When generating a Folio in InDesign CS6 I get the messagge: “Error generating content. [Error: Impossible to find the resources of one or more layers. Check that the resources utilized are available on the disk, then apdate the article.]
The preliminary check shows a green light, all the links are connected.
I started this project with a trial version of InDesign CS6 in English, then my company gave me a registered copy in Italian. Could this be the reason of the problem or there is something else?
    Aug 31, 2012 2:51 AM   in reply to Diwans
    Moved to DPS...
    Aug 31, 2012 3:03 AM   in reply to Diwans
    Run the "AdobeContentViewer.air" installer found in the following location:
    Mac OS: /Applications/Adobe
    Windows: C:/Program Files/Common Files/Adobe
    Note: If you do not see that file there, you can download the latest Folio Producer component updater from the following locations. To avoid this issue, click Yes when prompted to install or update the Content Viewer.
    Windows : http://www.adobe.com/support/downloads/detail.jsp?ftpID=5376
    Mac : http://www.adobe.com/support/downloads/detail.jsp?ftpID=5377
    Aug 31, 2012 5:28 AM   in reply to Diwans
    Is that an English error or translated from Italian? Does this happen with just this folio or all folios? Is it one orientation of two? Do you have the _h or _v in the file name?
    Bob
    Aug 31, 2012 6:06 AM   in reply to Diwans
    Are the files for the controller named correctly?
    Bob
    Aug 31, 2012 6:20 AM   in reply to Diwans
    Try and rename using the suggested format, ending with _play.png/_pause.png
    Aug 31, 2012 6:23 AM   in reply to Diwans
    You need a play and pause. Rename the files.
    Bob
    Aug 31, 2012 6:30 AM   in reply to Diwans
    Ok so look at my last reply, rename the files so that the name ends with _play.png/_pause.png
    eg:
