SIngle Edition / publication issue regarding FOlio orientation
Aug 31, 2012 8:10 AM
from french
An error happened during the publication
One of your articles does not match match the folio's orientation.
Articles orientations must match the folio's orientation
thing is, all my articles (10) are horizontal (single pages except on article whiwh is two pages where i force the horizontal view)
I really can't see what's wrong
    Aug 31, 2012 8:15 AM   in reply to Seb Adore
    I don’t understand what you mean by that. What does force horizontal view mean?
    All articles MUST be the same orientation and you should always use _h and _v in the file names.
    Bob
    Aug 31, 2012 8:56 AM   in reply to Seb Adore
    To Seb Adore,
    All the horizontal files have to be the same within the folio builder panel you may have added content with the incorrect orientation within the folio builder ,if you create horizontal single folios then adding both landscape and portrait orientations to The mix may have caused this error within you articles and the folio's.
    Regards
    Vividi
    Aug 31, 2012 9:13 AM   in reply to Seb Adore
    Folio can be portrait-only, landscape-only, or dual orientation. To preview or publish the folio, all articles must match the folio orientation. Example: If you create portait orientation folio, all articles must be of same layout(potrait). So if you want to add both horizontal and vertical article, create dual orienation folio from folio builder panel and add both horizontal and vertical layout aticles.
    Please check below link:
    http://help.adobe.com/en_US/digitalpubsuite/using/WS9293e1fb3b977c5c7b 1f65ad12f28224932-7fff.html
    Aug 31, 2012 9:21 AM   in reply to Seb Adore
    Check the folio builder panel and make sure you only selected horizontal orientation there. The default for that is dual orientation.
    Bob
    To Seb,
    Within the folio builder you can select Single Vertical,Single Horizontal, also Single and Horizontal orientations I found that you need to always select the exact orientation before uploading to the folio builder as this can cause some problems.
    " I used Horizontal to show a two page view but did not select it correctly inside the folio builder when adding it to a single orientation vertical folio, and this caused me some problems in my own folio's".
    You say your older folios worked fine but they are not working now,maybe has something to do with the current viewer or a bug.
    Regards
    Vividi
    Aug 31, 2012 9:34 AM   in reply to Seb Adore
    You need to create a new folio and select landscape orientation while creating.
    Aug 31, 2012 9:43 AM   in reply to Mohammed Yasin Khan
    You’ll want to click the middle button as shown on MYK’s screen shot.
    Bob
    Aug 31, 2012 9:54 AM   in reply to Mohammed Yasin Khan
    That's Right,
    See the DPS feature request for further thoughts on orientations.
    Regards
    Vividi
