Lenaped
Playing random movieclips via timeline without repeating
Aug 31, 2012 12:30 PM
I have eight movie clips on my main timeline. The idea is to play the first movie clip, once a button is clicked, go to a random frame 2-8 on the timeline and play the movielip on that frame, the get sent back to frame 1 to start the process over. I have this figured out, but I also don't want any frames repeating until they have all been played. Inside the first movieclip is a button with the following actionscript attached. Everything works perfectly EXCEPT my frames are repeating before they have all played. I can't see in my script where I have gone wrong. Please help!
var nums:Array = new Array();
1,2,3,4....
for(var i:uint=1; i<7; i++){
nums.push(i);
// for shuffling the array
function shuffle(a:Array) {
    var p:int;
    var t:*;
    var ivar:int;
    for (ivar = a.length-1; ivar>=0; ivar--) {
        p=Math.floor((ivar+1)*Math.random());
        t = a[ivar];
        a[ivar] = a[p];
        a[p] = t;
// shuffle the array
shuffle(nums);
// set up the controls for the button
var count:uint = 0;
boxButton.addEventListener(MouseEvent.CLICK, plyRndmMv);
function plyRndmMv(evt:MouseEvent):void {
    MovieClip(root).gotoAndStop(nums[count]+2);
    count++;
    if(count == 8){
        shuffle(nums);
        count = 0;
  • kglad
    Jul 21, 2002
    Aug 31, 2012 12:46 PM   in reply to Lenaped
    if that code is on frame 1, you have a problem.  if it is, you can use a boolean to prevent that code from repeatedly executing every time you return to that frame.
    1,2,3,4....
    nums.push(i);
    function shuffle(a:Array):Array {
        var randomArray=new Array();
        var p:int;
        var t:*;
        var ivar:int;
         while(a.length>0){
           p=Math.round(a.length-1*Math.random());
            randomArray.push(a[p])
            a .splice(p, 1);
         return randomArray;
    shuffle(nums);
    var count:uint = 0;
        count++;
        if(count == 8){
            nums=shuffle(nums);
            count = 0;
    Aug 31, 2012 12:49 PM   in reply to esdebon
    the problem is:
            t = a[ivar];
            a[ivar] = a[p];  // <  HERE p can be a number for example 2 then p can be again 2 and then 2...
            a[p] = t;
  • kglad
    Jul 21, 2002
    Aug 31, 2012 1:08 PM   in reply to esdebon
    esdebon,
    there's nothing wrong with the shuffle() function.  that's an implementation of the fisher-yates shuffle.
    go experiment/study it but please don't confuse the op.
  • kglad
    Jul 21, 2002
    Aug 31, 2012 1:10 PM   in reply to Lenaped
    use:
    var alreadyExecuted:Boolean;
    if(!alreadyExecuted){
    alreadyExecuted=true;
    1,2,3,4....
    nums.push(i);
        var p:int;
        var t:*;
        var ivar:int;
            t = a[ivar];
            a[ivar] = a[p];
            a[p] = t;
    shuffle(nums);
    var count:uint = 0;
        count++;
        if(count == 8){
            shuffle(nums);
            count = 0;
  • kglad
    Jul 21, 2002
    Aug 31, 2012 2:11 PM   in reply to Lenaped
    it is assigned to true if you copied that code.
    what do the traces reveal:
    //1,2,3,4....
    for(var i:int=2; i<=8; i++){
    nums.push(i);
        var p:int;
        var t:*;
        var ivar:int;
            t = a[ivar];
            a[ivar] = a[p];
            a[p] = t;
    shuffle(nums);
    trace(nums);
    var count:uint = 0;
        MovieClip(root).gotoAndStop(nums[count]);
    trace(nums[count]);
        count++;
        if(count == 8){
            shuffle(nums);
            count = 0;
  • kglad
    Jul 21, 2002
    Aug 31, 2012 3:17 PM   in reply to kglad
    are you sure you're using the code i suggested?  did you change anything??
    it looks like you're either not assigning alreadyExecuted=true or you're using:
    var alreadyExecuted:Boolean = false;
    instead of
  • kglad
    Jul 21, 2002
    Aug 31, 2012 3:58 PM   in reply to Lenaped
    if that code is in a movieclip and that movieclip is re-initialized each time some other timeline (ie, the parent's timeline) returns to frame 1, that will cause the problem you're seeing.
    put that code (or, at least, the alreadyExecuted part of it) on your main timeline.
  • kglad
    Jul 21, 2002
    Sep 4, 2012 12:51 PM   in reply to Lenaped
    if your button is being reinitialized, you need to re-execute its listener code.  ie, remove  boxButton.addEventListener(MouseEvent.CLICK, plyRndmMv); from the if(!alreadyExecuted) block:
    //1,2,3,4....
    for(var i:int=359; i<=365; i++){
    nums.push(i);
        var p:int;
        var t:*;
        var ivar:int;
            t = a[ivar];
            a[ivar] = a[p];
            a[p] = t;
    shuffle(nums);
    trace(nums);
    var count:uint = 0;
    trace(nums[count]);
        count++;
        if(count == 7){
            shuffle(nums);
            count = 0;
  • kglad
    Jul 21, 2002
    Sep 4, 2012 1:39 PM   in reply to Lenaped
    you're welcome.
