coyott07
Why does the drop-down menu with a Spry Widget 2.0 take two taps to activate on iPad?
Aug 31, 2012 7:17 AM
I have the Spry Menu 2.0 pretty much dialed in how I want it.  However, when the user taps the menu item from an iPad or iPhone for that matter, they have to tap the drop-down menu item twice for it to work.  All the menu items work fine on the first tap except ones that have a drop-down.  Is there a way to get the drop-down to pop up and work on the first tap from an iPad?  Here is the code of that helps.
<ul id="MenuBarUpgradeAugust2012">
        <li> <a href="default.html">Home</a></li>
        <li><a href="apps4kids.html">About</a></li>
        <li><a class="MenuBarItemSubmenu">Our Apps</a>
          <ul>
            <li> <a href="Rhyme-N-Time.html">Rhyme-N-Time</a></li>
            <li> <a href="Free-The-Bee.html">Free The Bee</a></li>
            <li> <a href="Trojan-Math.html">Trojan Math</a></li>
            <li> <a href="Helping-Santa.html">Helping Santa</a></li>
          </ul>
        </li>
        <li> <a href="smart-apps.html">Contact</a></li>
      </ul>
Scott
    Aug 31, 2012 7:59 AM   in reply to coyott07
    I don't quite understand. Do they have to tap the dropped down items twice, or the menu item with the drop down twice?
    Example for clarification:
    Menu Item 1 - Menu Item 2 - Menu Item 3
    sub 1
    sub 2
    So they tap Menu Item 2 or 3 once and it goes to the link. Are you talking about tapping twice on "Menu Item 1" or needing to tap twice on "sub 1" or "sub 2"
    Sep 1, 2012 11:30 AM   in reply to coyott07
    Spry menus use JavaScript mouseover and mouseout events to trigger submenus. These are the equivalent of hovering. You can't hover on a touch-screen device. A single tap activates a link if one's there. If there's no link, tapping twice activates the submenu.
    The bottom line is that Spry menus weren't designed for touch-screen devices.
    Sep 1, 2012 11:52 AM   in reply to David_Powers
    Hi David,
    Actually, that sounds backwards (but it is Spry In a mobile device,
    if a root item is both a live link and a trigger for a sub-menu, the
    first tap should reveal the sub-menu and a second tap should execute the
    link. On a root item that is a null link and a sub-menu trigger, the
    first tap reveals the sub-menu and a second tap closes the sub-menu. I
    know one menu system for Dreamweaver that actually does that
    Al Sparber - PVII
    http://www.projectseven.com
    The Finest Dreamweaver Menus | Galleries | Widgets
    Since 1998
    Sep 1, 2012 2:36 PM   in reply to Al Sparber
    I haven't played around with Spry menus on touch-screen devices, but I did a lot of testing recently with the effect of hover on Android and iOS devices. What I found was that if a menu item has a direct link to a page, Android devices follow the link immediately without displaying any submenu. On iOS, tapping the link once displays a submenu if one exists. To follow the link, you have to tap twice.
    The bottom line remains that drop-down/flyout menus designed for mouse-driven events need to be redesigned for touch screens.
    Sep 2, 2012 9:56 AM   in reply to coyott07
    If you are trying to fix the Spry menu, I think the amount of coding it would take would not be worth the effort. I would use a more modern menu system. The jQuery Superfish menu would work, I believe, as you want in mobile devices - or if you have a budget and want lots of features and lots of automation, I know our menu system would work. Here is a live example with real links on the menu so you can test on mobile:
    http://www.projectseven.com/products/menusystems/pmm2/testing/mobile/i ndex.htm
