Whenver I try to install the update to CS6 it fails the install with error code U44M1P7. I'm running Mac OS 10.7.4 and there is no antivirus running. CS6 was purchased as part of Creative Cloud if that makes a difference for any reason.
What update are you trying to apply? You can find the log files for the update in Library/Logs/Adobe/Installers. You can find directions on how to review the log files at Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5-cs5.html.
Download the update manually from the Adobe site and install it.
Mylenium
Tried that and still fails. This time with error code U44M2P7.
Still didn't work.
Hello, I am getting an error while updating CS6.
I get the error for:
- Adobe Bridge CS6 5.0.1 Update
- Adobe Illustrator CS6 Update (version 16.0.1)
- DPS Desktop Tools CS6 2.04 Update
- Adobe Media Encoder CS6 6.0.2 Update
- Photoshop 13.0.1 update for Photoshop CS6 and Photoshop CS6 Extended
They all get the same error code and message: "There was an error installing this update. Please quit and try again later. Error Code: U44M1I200"
As Mylenium mentioned previously in message #1 please first try applying the update directly from the Product update page at http://www.adobe.com/downloads/updates/.
If you continue to experience difficulties then please review the log files for that update as directed in message #4.
If you wish guided assistance for reviewing your log files then please contact our support team when they open on Monday.
Thanks for your help. I couldn't find that link before.
Yeah I've tried it both ways and still have the problem. I gave up, but
since this email came, I've decided to call customer support on Monday.
As some others experienced above: With the standard updater as well as with the downloaded patch the negative result is the same. The link to the error log provides the not very helpfull message 'Adobe Bridge CS6 5.0.1 Update
Installation failed. Error Code: U44M2P7'
The installation log (error message at the end of the log in italics and with a bigger font size):
Installer Operation: PayloadInstaller
Request to install payload
Payload {5BCA5B05-A805-42A3-86F8-6689B7C1E907} Adobe Bridge CS6_5.0.1_AdobeBridge5-mul 5.0.1.0: Calling ARKEngine from path /Applications/Utilities/Adobe Application Manager/DECore/DE6/resources
[ 1] Tue Sep 25 13:54:35 2012 INFO
CustomizedPatch property not found in database
Beginning installation for payload at /private/tmp/.tempdir4IyaNZNL/Install.db
[ 1] Tue Sep 25 13:54:35 2012 ERROR
DS015: Unable to read symlink target of source file "/Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/MacOS/Photo Downloader.app/Contents/MacOS/plugins/Cineon.plugin/Contents/CodeResources"(Seq 2)
DW063: Command ARKCopySymlinkCommand failed.(Seq 2)
Completing installation for payload at /private/tmp/.tempdir4IyaNZNL/Install.db
[ 0] Tue Sep 25 13:54:35 2012 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{5BCA5B05-A805-42A3-86F8-6689B7C1E907}] took 1646 milliseconds (1.646 seconds) DTR = 4.86027 KBPS (0.00474635 MBPS)
User specified overrideFile:
The csu inventory was not updated for payload {5BCA5B05-A805-42A3-86F8-6689B7C1E907} Adobe Bridge CS6_5.0.1_AdobeBridge5-mul 5.0.1.0, value of local var is -1
Calling the ROLLBACK custom action code for pre-install for payload {5BCA5B05-A805-42A3-86F8-6689B7C1E907} Adobe Bridge CS6_5.0.1_AdobeBridge5-mul 5.0.1.0
No operation. We're done:
[ 0] Tue Sep 25 13:54:37 2012 INFO
Total components installed: 0
Total components repaired: 0
Total components removed: 0
[ 0] Tue Sep 25 13:54:37 2012 ERROR
DW050: The following payload errors were found during install:
DW050: - Adobe Bridge CS6_5.0.1_AdobeBridge5-mul: Install failed
Call PostSession Custom Hook
:: END TIMER :: [Total Timer] took 6530 milliseconds (6.53 seconds) DTR = 1.83767 KBPS (0.0017946 MBPS)
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 3 error(s), 0 warning(s)
----------- Payload: {5BCA5B05-A805-42A3-86F8-6689B7C1E907} Adobe Bridge CS6_5.0.1_AdobeBridge5-mul 5.0.1.0 -----------
ERROR: DS015: Unable to read symlink target of source file "/Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/MacOS/Photo Downloader.app/Contents/MacOS/plugins/Cineon.plugin/Contents/CodeResources"(Seq 2)
ERROR: DW063: Command ARKCopySymlinkCommand failed.(Seq 2)
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Adobe Bridge CS6_5.0.1_AdobeBridge5-mul: Install failed
Please search the above error/warning string(s) to find when the error occurred.
These errors resulted in installer Exit Code mentioned below.
[ 0] Tue Sep 25 13:54:38 2012 INFO
Exit Code: 7 - Unable to complete Silent workflow.
Please see specific errors and warnings for troubleshooting. For example, ERROR: DS015, DW063 ...
END - Installer Session
The problem is that a source file is missing but why is it missing after having installed the original version and the previous patches without any errors? Any hint how to proceed is appreciated!
Mkoth if you view the package contents of the final package of Cineon.plugin? The DW063 error can also be due to permissions. If you have verified the plugin exists then you may want to try adjusting the read/write permissions of Adobe Bridge CS6 folder and sub-directories.
If the Cideon.plugin is missing then you will need to remove all CS6 applications which utilize Adobe Bridge and then reinstall.
OK, I checked the complete path as described in the log and it exists until /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/MacOS/Photo Downloader.app/Contents/MacOS/plugins/Cineon.plugin/Contents/ but after it continues with _CodeSignature/CodeResources . To be honest I have doubts that a (complex) reinstallation will change the directory structure because the installation package didn't change. The access rights from the beginning to the end are "sytem rw, admin r/w, everone read only" and I have admin rights. I still supect that the patch package searches for a wrong path. Any further ideas on this?
I verified on my own installation that the complete path does exist. If it isn't on your system then reinstalling would be the most likely way to ensure that CodeSignature/CodeReources exist.
Alternately you could try copying this resource from another installation if you have one available to you?
Jeff,
sorry that I expressed myself in a misunderstandable way. For clarification: The path of my CS6 installation is
/Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/MacOS/Photo Downloader.app/Contents/MacOS/plugins/Cineon.plugin/Contents/_CodeSignature/CodeResources
while the log of the patch installation indicates that the installation script searches for the path
/Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/MacOS/Photo Downloader.app/Contents/MacOS/plugins/Cineon.plugin/Contents/CodeReso urces
as you can see the node _CodeSignature/ is missing in the installation procedure path and I am not sure whether the blank in
CodeReso urces is only a typo in the log or if it is used by the installation procedure as written. If your CS6 installation shows the same path than mine (including _CodeSignature/) then the patch installation must be looking for the wrong path. If the path string is created dynamically during the installation this could well be. As this discussion stream indicates I am not the only one with this problem
Manfred Koth
