how to extend mpeg video menu
Sep 1, 2012 11:11 AM
I have a menu (f.i. PAL Nightlife) which duration is 16.20. sec. I have a musicscore under this menu which has a duration of 30.00 sec. In the menu I have an animated button with video of the same length (30 sec). What happened is that, after 16.20, the menubackground dissapears The video (button) with the audio plays further until end (30 sec) on an black background.
The settings on the menu (motion) are: video: Pal Nightlife, Audio: audioclip 30 sec, duration set to 30 sec. Animated button "on"  loop point "00, loop "none"
Is there a possibiliy to extend the (standard in encore) menuvideo nightlife from 16.20 till 30.00 so that both, "buttonvideo" and "backgroundvideo" end the same time? Thanks for replying
Chris
    Sep 1, 2012 12:18 PM   in reply to Chris Nierop
    You can't in Encore.
    You'll get a re-transcode and lose some quality, but here's an option:
    Copy the m2v from the Encore library to another location. Import the copy into Premiere. Drag it to the new item icon. Drag the clip again onto Video tgrack 2, so that the end of it is a 30 seconds (or whatever). Play it through; look okay? (for the 30 second version it looked okay to me.)
    You have the same beginning/end as orginally designed.
    Export as m2v. (There's the quality loss.)
    Note that the orig m2v appears to be 3 or 4 shorter repetitions together.
    Sep 1, 2012 1:14 PM   in reply to Chris Nierop
    It depends; you won't know until you try it in a burned disk.
    Sep 1, 2012 2:12 PM   in reply to Chris Nierop
    Player quality can be an issue. But just for menu looping, getting the audio/video length match appears to be an issue. Also, some durations are issues. Don't recall the specifics at the moment.
