captcurrent
Poriblems with Server Side Include
Sep 1, 2012 2:00 PM
Tags: #php #ssi
I amtrying to convert to Spry Menus using SSI. into a template.  been beating my head against the wall on what can go in and what can't in an include fil but that turns out not be my big problem
when in using Dredamweaver CS5   and  do a server side I have major issues at the differeent levels
i have the file in a directory off the site root called  Includes
the file i am trying to include
using a page at the root level my statement using document relation is
<!--#include file="Includes/Navbar.html" -->
works fine   channg to site relation does not work   Ok so far so good
however a page in a lower level director gets the dreaded
[an error occurred while processing this directive]
and i get an error
[Sat Sep 01 16:51:42 2012] [error] [client 174.57.220.98] unable to include file "../Includes/Navbar.html" in parsed file /usr/local/www/kasdivi.com/blog/beachguide.html
and also
Warning - PHP Startup: Unable to load dynamic library '/usr/local/lib/php/20100525-debug/memcache.so' - Cannot open &quot;/usr/local/lib/php/20100525-debug/memcache.so&quot;
Unknown(0) : Warning - PHP Startup: Unable to load dynamic library '/usr/local/lib/php/20100525-debug/apc.so' - Cannot open &quot;/usr/local/lib/php/20100525-debug/apc.so&quot;
Unknown(0) : Warning - PHP Startup: Unable to load dynamic library '/usr/local/lib/php/20100525-debug/pdf.so' - Cannot open &quot;/usr/local/lib/php/20100525-debug/pdf.so&quot;
Unknown(0) : Warning - PHP Startup: Unable to load dynamic library '/usr/local/lib/php/20100525-debug/memcache.so' - Cannot open &quot;/usr/local/lib/php/20100525-debug/memcache.so&quot;
the php errors don't seem mahor although they seem to have i have another iisue or are the related
but that aside
If I move the include file to the same level as the pade with approprirate include statement no problem it works
if i move it to a subditrectory  then it doesn't work
summary
i can get SSI to work for page on the root level using Includes from a subdirectory
but on other level I must have the include in the same directory with the page
any thoughts??
    Sep 1, 2012 2:32 PM   in reply to captcurrent
    Your menu links are inside an include file.  There should be nothing else inside that file except the list tags, classes & hyperlinks.  Links are relative to the parent page(s) in which they will occur.
    All supporting scripts and CSS go inside the parent page -- in your case, the Template.dwt file.
    Local Files Panel:
         -Includes
              menu.html
              footer.html
         +Styles
         +SpryAssets
         -Templates
              main.dwt
         about.shtml
         contact.shtml
         index.shtml
         services.shtml
    Problems will occur if you use document relative link paths with pages that are located inside sub and sub-sub folders. Obviously, you want to avoid doing that.  For best results, keep all your site pages at root level.
    Hope this helps,
    Nancy O.
    Sep 1, 2012 3:39 PM   in reply to captcurrent
    You can still use SSIs.  Read this Help article.
    Absolute, document-relative, and site root-relative paths
    http://help.adobe.com/en_US/dreamweaver/cs/using/WScbb6b82af5544594822 510a94ae8d65-7c44a.html
    Nancy O.
    Sep 2, 2012 4:49 AM   in reply to captcurrent
    Root relative will work just fine.  No need to use absolute....
    Sep 2, 2012 5:26 AM   in reply to captcurrent
    If they didn't work, then you must not have implemented them properly.  They do work, and they will work in this circumstance.  The reason one would want to use root relative links rather than absolute links is that DW can manage the former, but not the latter, so if you ever change a file name or move a file within DW I believe that there will be problems with absolute links (although I haven't tested this).
    Sep 2, 2012 5:36 AM   in reply to captcurrent
    Can you show what you tried that did not work?
    Sep 2, 2012 7:20 AM   in reply to captcurrent
    Of course, when a link to an include file works, then I cannot see what the link looks like.  When it does not work, it's replaced by an error message, and once again, I cannot see what the link looks like -
    <div id= "nav">
    </div>
    But I see what the problem is.  You are making the link to the include file root relative.  That's not the right approach.  Make that link document relative.  DW will manage those links just fine.  It's the links WITHIN the file being included that must be root relative.  So -
    your second file linked above should have this -
    <div id= "nav">
    </div>
    (I'm assuming you have set your server to parse all document extensions so that the include directives are found and executed)
    ALL of the links within the files being included should be root relative (I can see that MOST but not all of them are).
    Sep 2, 2012 9:05 AM   in reply to captcurrent
    Your site definition for the Remote site must be adjusted to show kasdivi.com as the root folder.
    Sep 2, 2012 10:19 AM   in reply to captcurrent
    This change should have no impact on those other attributes.
