Ediaz5
Error Code: DW050
Aug 22, 2012 7:44 PM
Tags: #error #dw050
I am trying to download the free trail of the Creative Cloud & whenever I try to download Photoshop I keep getting Error DW050. I dont know if this might be a factor in it or not, But I would like to mention that I am still running on Snow Leopard & have CS4 installed. Below is message I keep getting.
Exit Code: 7
Please see specific errors and warnings below for troubleshooting. For example,  ERROR: DW050 ...
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 37 error(s), 0 warning(s)
ERROR: Updating driver data failed. Driver entry was notadded. ARP estimated size 0KB
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050:  - Suite Shared Configuration CS6: Install failed
ERROR: DW050:  - Adobe Linguistics CS6: Install failed
ERROR: DW050:  - Dynamic Link Media Server: Install failed
ERROR: DW050:  - AdobeColorCommonSetCMYK CS6: Install failed
ERROR: DW050:  - Adobe XMP Panels: Install failed
ERROR: DW050:  - Adobe Photoshop CS6 Support: Install failed
ERROR: DW050:  - Adobe Player for Embedding 3.3: Install failed
ERROR: DW050:  - AdobeColorJA CS6: Install failed
ERROR: DW050:  - Adobe Photoshop CS6 English Language Pack_AdobePhotoshop13-en_US: Install failed
ERROR: DW050:  - Required Common Fonts Installation: Install failed
ERROR: DW050:  - Adobe CSXS Infrastructure CS6: Install failed
ERROR: DW050:  - PDF Settings CS6: Install failed
ERROR: DW050:  - AdobeColorPhotoshop CS6: Install failed
ERROR: DW050:  - Adobe Utilities CS6: Install failed
ERROR: DW050:  - Adobe SwitchBoard 2.0: Install failed
ERROR: DW050:  - Adobe ExtendScript Toolkit CS6: Install failed
ERROR: DW050:  - AdobeColorEU CS6: Install failed
ERROR: DW050:  - Camera Profiles Installer: Install failed
ERROR: DW050:  - AdobePDFL CS6: Install failed
ERROR: DW050:  - Adobe Photoshop CS6 Driver: Install failed
ERROR: DW050:  - AdobeColorVideoProfilesCS CS6: Install failed
ERROR: DW050:  - Adobe Extension Manager CS6: Install failed
ERROR: DW050:  - PDF Settings CS5: Install failed
ERROR: DW050:  - Adobe Photoshop CS6 Core: Failed due to Language Pack installation failure
ERROR: DW050:  - Adobe Bridge CS6: Install failed
ERROR: DW050:  - AdobeTypeSupport CS6: Install failed
ERROR: DW050:  - Adobe WinSoft Linguistics Plugin CS6: Install failed
ERROR: DW050:  - Adobe Hunspell Linguistics Plugin CS6: Install failed
ERROR: DW050:  - Adobe Mini Bridge CS6: Install failed
ERROR: DW050:  - AdobeColorNA CS6: Install failed
ERROR: DW050:  - AdobeColorCommonSetRGB CS6: Install failed
ERROR: DW050:  - Photoshop Camera Raw 7: Install failed
ERROR: DW050:  - Recommended Common Fonts Installation: Install failed
ERROR: DW050:  - DynamiclinkSupport: Install failed
ERROR: DW050:  - AdobeCMaps CS6: Install failed
ERROR: DW050:  - Adobe CSXS Extensions CS6: Install failed
    Aug 23, 2012 1:43 PM   in reply to Ediaz5
    Are you running Mac OS 10.6.8?  Beyond that there is nothing actionable in the current errors you have posted.  I would recommend reviewing your installation logs to determine what is causing your current difficulty.  You can find details on how to accomplish this at Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5 -cs5.html.
    Aug 24, 2012 8:09 AM   in reply to Ediaz5
    No 10.6.8 should be fine.  You will need to review the install logs indicated in message #1 to determine the point of failure.
    Alternately you can run the Adobe Support Advisor - http://www.adobe.com/support/loganalyzer/ to attempt to automatically review your install logs.  There is also a package for support option available.  If you wish to respond to this thread with the token number which it provides you.  Myself or another Adobe Employee can then review your logs using that token number.
    I would still recommend though reviewing the install logs yourself as well if you decide to follow this route.
    Aug 31, 2012 3:48 PM   in reply to Ediaz5
    This would certainly be a problem Ediaz5.  I checked both of my Mac systems and I do have such a directory.  Have you tried navigating to that location to see if it does exist?
    Sep 2, 2012 10:33 AM   in reply to Ediaz5
    This is your System folder.  If you are missing components from here then please back up your documents and settings and reinstall your operating system.
