Template Problem
Sep 2, 2012 10:35 AM
Tags: #cs4 #template #file_reference
My template contains this file reference:
<a href="../../racing/calendar/eventDetail.asp?<%= Server.HTMLEncode(MM_keepNone) & MM_joinChar(MM_keepNone) & "ID=" & rsdistrictEvents.Fields.Item("ID").Value %>" target="_blank" class="magenta"><%=(rsdistrictEvents.Fields.Item("regatta").Value)%>< /a></td>
When applying the template, this is what happens:
<a href="file:///C|/inetpub/racing/calendar/eventDetail.asp?<%= Server.HTMLEncode(MM_keepNone) & MM_joinChar(MM_keepNone) & "ID=" & rsdistrictEvents.Fields.Item("ID").Value %>" target="_blank" class="magenta"><%=(rsdistrictEvents.Fields.Item("regatta").Value)%>< /a></td>
Why is the href resolving to file:///C/inetpub/ ? I there a way to correct this problem?
    Sep 2, 2012 10:38 AM   in reply to sherleon
    Did you save the file within the defined site?  If a file is not saved within a defined DW site, the paths will be local paths until the file is saved.
    Sep 2, 2012 2:37 PM   in reply to sherleon
    File > New > Page from Template (select your template.dwt).
    SaveAs test.html
    Switch to code view, what do you see?
    Nancy O.
    Sep 2, 2012 2:51 PM   in reply to sherleon
    Is that the path to your local root folder as stated in your site definition?
    Sep 2, 2012 2:52 PM   in reply to Nancy O.
    Probably should insert an image or create a link to another page before saving, Nancy.
    Sep 3, 2012 4:34 AM   in reply to sherleon
    Is there a clue there?
    Yes.
    I did exactly that and got the same result.
    Your link is this -
    DW thinks that this file is NOT IN THE LOCAL ROOT FOLDER, so it makes the kind of link that allows it to work with files that are outside of your site. This almost always means that your site is not defined properly.  In your site definition, what is the path to your local root folder?
