bdubz_87
Tag 'pseq': Required tag is not present in .icc color profile - Mac OS X Lion
Jun 2, 2012 6:00 AM
Tags: #profile #color #color_management_problem #color_management #management #color-management #.icc
I am using a trial version of Adobe CS6 on Mac OS X Lion. I have installed the most recent updates for both softwares and now when I run the Color Sync Utility I get the following errors. Any support is appreciated.
Searching for profiles...
Checking 68 profiles...
/Library/Application Support/Adobe/Color/Profiles/RedBlueYelllow.icc
   Tag 'pseq': Required tag is not present.
/Library/Application Support/Adobe/Color/Profiles/Smokey.icc
/Library/Application Support/Adobe/Color/Profiles/TealMagentaGold.icc
/Library/Application Support/Adobe/Color/Profiles/TotalInkPreview.icc
Verify done - found 4 bad profiles.
   Tag 'pseq': Required tag is not present. Could not be fixed.
Repair done - 0 out of 4 profiles fixed.
  • Andrew Rodney
    Apr 16, 2009
    Jun 2, 2012 9:47 AM   in reply to bdubz_87
    Assuming they show up in Photoshop or other ICC aware app’s and you can use them, just ignore the errors. All these described above appear to be LUT’s anyway (only useful in CS6 with the new LUT tools).
    Aug 31, 2012 2:32 AM   in reply to Andrew Rodney
    I have the same issue with Full version Production Pack CS6 on 10.8. How to fix this? Thank you
    Sep 2, 2012 6:33 PM   in reply to bdubz_87
    I have this exact issue. I have CS6 Extended on Mac 10.7.4. How do I fix this? Will downloading and installing Adobe Color Profiles help?
