Only 1 of 3 text fields is entered
Aug 31, 2012 9:12 PM
How would I use Spry so the viewer can only enter data in 1 text field out of a total of 3 text fields in a form and validate so 1 field must be entered. Or CSS perhaps?
BTW I'm using CS5
    Sep 1, 2012 1:57 PM   in reply to gofer
    How about three radio buttons and only one text field that will not validate if empty?
    Sep 1, 2012 2:42 PM   in reply to gofer
    In what way do they mess with your calculations? Radio buttons are indeed the right way to do this.
    Sep 2, 2012 4:53 AM   in reply to gofer
    Can you say again which fields is it that are causing you problems and how would you like the form to work?
    Sep 2, 2012 2:46 PM   in reply to gofer
    The problem is that the JavaScript function you're using works only with text fields. It's not designed to work with radio buttons or other types of form input. There's a copyright notice with your CalculateTotal() script. If it's a script that you have paid for, you should ask the creator of the script to make it compatible with radio buttons. If it's a free script, it can be adapted to work with radio buttons, but it will take a little time to work out.
    Sep 2, 2012 3:54 PM   in reply to gofer
    gofer wrote:
    I did pay for CalculateTotal() script but I've since found the script on another site, the chap that I paid to create the script is not the person on the Copyright! And this guy wants more money to change to the script to be compatible with radio buttons
    It's sad that there are such disreputable people who will steal other people's copyright and charge. I've been playing around with the script, and it wasn't all that difficult to adapt. Try out the following:
    <!doctype html>
    <html>
    <head>
    <meta charset="utf-8">
    <title>Add Values</title>
    <script>
    function CalculateTotal(frm) {
        var order_total = 0
        // Run through all the form fields
        for (var i=0; i < frm.elements.length; ++i) {
            // Get the current field
            form_field = frm.elements[i]
            // Get the field's name
            form_name = form_field.name
            // Is it a "product" field?
            if (form_name.substring(0,4) == "PROD" && form_field.type != 'radio') {
                // If so, extract the price from the name
                item_price = parseFloat(form_name.substring(form_name.lastIndexOf("_") + 1))
                // Get the quantity
                item_quantity = parseInt(form_field.value)
                // Update the order total
                if (item_quantity >= 0) {
                    order_total += item_quantity * item_price
            } else if (form_name.substring(0,4) == "PROD" && form_field.type == 'radio' && form_field.checked == true) {
                order_total += parseInt(form_field.value);
         // Display the total rounded to two decimal places
        document.getElementById("order_total").firstChild.data = "$" + round_decimals(order_total, 2)
    function round_decimals(original_number, decimals) {
        var result1 = original_number * Math.pow(10, decimals)
        var result2 = Math.round(result1)
        var result3 = result2 / Math.pow(10, decimals)
        return pad_with_zeros(result3, decimals)
    function pad_with_zeros(rounded_value, decimal_places) {
        // Convert the number to a string
        var value_string = rounded_value.toString()
        // Locate the decimal point
        var decimal_location = value_string.indexOf(".")
        // Is there a decimal point?
        if (decimal_location == -1) {
            // If no, then all decimal places will be padded with 0s
            decimal_part_length = 0
            // If decimal_places is greater than zero, tack on a decimal point
            value_string += decimal_places > 0 ? "." : ""
        else {
            // If yes, then only the extra decimal places will be padded with 0s
            decimal_part_length = value_string.length - decimal_location - 1
        // Calculate the number of decimal places that need to be padded with 0s
        var pad_total = decimal_places - decimal_part_length
        if (pad_total > 0) {
            // Pad the string with 0s
            for (var counter = 1; counter <= pad_total; counter++)
                value_string += "0"
        return value_string
    </script>
    </head>
    <body>
    <form id="form1" name="form1" method="post" action="">
        <p>
            <input type="text" name="PROD_first_20" id="PROD_first_20" onChange="CalculateTotal(this.form)">
        </p>
        <p>
            <label>
                <input type="radio" name="PROD_freight" value="10" id="PROD_freight_0" onChange="CalculateTotal(this.form)">
                North</label>
            <br>
            <label>
                <input type="radio" name="PROD_freight" value="15" id="PROD_freight_1" onChange="CalculateTotal(this.form)">
                South</label>
            <br>
            <label>
                <input type="radio" name="PROD_freight" value="0" id="PROD_freight_2" onChange="CalculateTotal(this.form)">
                Nowhere</label>
        </p>
        <div id="order_total" style="text-align: right">$0.00</div>
    </form>
    </body>
    </html>
    What I have done is to adapt the CalculateTotal() function to work with radio buttons.
    Each radio button has the same name (the actual name is unimportant). The value attribute contains the value you want to add to the total.
    Sep 3, 2012 1:23 AM   in reply to gofer
    Hi gofer, instead of radio buttons (if you can't get those to work) you could use a 'select' list option. That should work, I've tested it. The 'select list' doesn't mess with the original javascript form calculations script (although David seems to have sorted this out for you now) and they return the correct totalprice via php.
    So you would insert a 'Select delivery option' on the form:
    select name="PROD_freight_1" onchange="CalculateTotal(this.form)">
        <option value="0" selected="selected">Collect Order $0</option>
    <option value="10">North Island $10</option>
    <option value="15" >South Island $15 </option>
    </select>
    Then amend the php freight variable to retreive the correct price:
    $freight = $_POST['PROD_freight_1'];
    Sep 3, 2012 1:53 AM   in reply to gofer
    Radio buttons share the same name. Look again at the sample I gave you:
    <p>
            <label>
                North</label>
            <br>
            <label>
                South</label>
            <br>
            <label>
                Nowhere</label>
        </p>
    They are all called PROD_freight, so the value your PHP code should be looking for is $_POST['PROD_freight']. That will contain the number stored in the value attribute.
    If you rename the radio buttons PROD_freight_15, PROD_freight_10, and PROD_freight_0, they become independent buttons, all of which can be selected. The whole point of a radio button group is that only one can be selected. But for that to happen, each button in the group must have the same name.
    Sep 3, 2012 2:10 AM   in reply to David_Powers
    This was a freely available script which I found on the net and passed onto Gofer. As long as the Copyright notice remains at the top of the script I think the writer is ok about it being used. Not sure what Gofer is alluding to about payment. As far as I know it went straight from me to Gofer.
    Sep 3, 2012 2:35 AM   in reply to osgood_
    Although a select menu would offer the same "single-choice" option as a set of radio buttons, it presents the same problem for the JavaScript function. The way the function has been designed is that it extracts the price from the input element's name, and uses it to calculate the total cost. That's why gofer had PROD_freight_10, PROD_freight_15, and PROD_freight_0. The function grabs the numbers after the second underscore.
    But radio button groups and select menus can have only one name, so you have to get the value from elsewhere. What I did was to adapt the script so that it handles radio buttons separately and gets the price from the value attribute of the selected button. The script could be adapted to do the same with a select menu. It would be slightly more complicated, but still easily done.
    Sep 3, 2012 2:41 AM   in reply to osgood_
    I don't know anything about the provenance of the script other that what I've read here. Obviously, there's a misunderstanding somewhere.
    I have now changed the script, but I think the copyright notice should stay in because most of the work was done by the original developer. I would suggest rewording the copyright notice like this:
    /* Adapted from a script that is
    Copyright (c) Paul McFedries and
    Logophilia Limited (http://www.mcfedries.com/).
    Permission is granted to use this script as long as
    this Copyright notice remains in place.*/
    Sep 3, 2012 2:43 AM   in reply to David_Powers
    Hi David,
    It doesn't if you use the value 1 for PROD and then give the select options 10, 15 or 0 respectively. The script then seems to x it by that total based on 1 and add the correct value to the overall form total, job done! I could not do that with the radio buttons because as you say unless the javascript is amended (which I could'nt do) it messes up the calculations.
    Sep 3, 2012 2:47 AM   in reply to osgood_
    Ah, I see what you mean. You're setting the price as 1 and then multiplying the price by the selected value. Clever stuff!
