Trial Reader Extensions credentials error
Aug 19, 2012 6:51 AM
Tags: #error #reader #extensions
Hello experts
I have just installed Windows x64 turnkey version of LC server.
I got some errors during installation (admittedly I should have make a note of these, sadly I havent) however these were not particulary descriptive so I have decided to continue and see if I will be able to fix these later.
At the moment I only had a look at admin console (seems to work fine) and I tried to launch Reader Extensions module but latter does not want to start. After logging in I am presented with following message:
Application alert
A fault occured while trying to access the list of Reader Extensions credentials
and subsequently I am being logged off.
I tried to find the cause of that issue in Trust Store to no avail.
Can anyone help?
Regards
Michael
    Aug 20, 2012 4:47 AM   in reply to Michael Orzechowski
    I'd recommend restarting the server and checking the server log for errors.  Also, have you installed the RE cert in the trust store as a local credential it should look like the following:
    ARES
    C=US,O=Adobe Systems Incorporated,OU=Adobe Trust Services,CN=ARE IDev V6.1 P19 0009278
    CN=Product Services,OU=Adobe Trust Services,O=GeoTrust Inc.,C=US
    Tuesday, December 6, 2011
    Sep 3, 2012 6:16 AM   in reply to Michael Orzechowski
    Michael,
    Please attach the logs if you have from your previous setup which ran in to issues , Did that server had previous versions of Adobe LiveCycle running on it?
    Are there are any issues with the current installation on clean system ?
