Illustrator fills curves unwanted
Sep 3, 2012 5:55 AM
Tags: #illustrator #fill #curves
when using my own brushes in Illustrator (which aren't very complictated, just "pressure-sensitive" as you can see in the example)...
... Illustrator fills the curves automatically.
Not, when I'm drawing large format, but once in a while I have to draw small vignettes or want to reduce the size. Small means: about a centimeter.
First I thought it might be a problem with the wacom tablet I got, but the support convinced me, that it had to be a problem with the software... I had the same problem already with CS3 and 4, now again with CS6.
Maybe it's only a problem with the settings, but it drives me crazy.
Thanks a lot,
Staubfluse2000
    Sep 3, 2012 7:26 AM   in reply to Staubfluse2000
    It's a long-existing problem with AI's Brushes. Sometimes making small anchorPoint/handle adjustments can correct it. For a crude fix, sometimes running the Add Anchor Points command can help.
    JET
