anonmous
Hue Blend Mode Confusion
Sep 3, 2012 10:22 AM
Tags: #photoshop #hue #cs6 #blend_mode
Hello,
  In reading about the Hue blend mode, I have come to understand (perhaps erroneously) that given two layers (T)op and (B)ottom, that if the Blend Mode of T is set to Hue, then the hue information in T will be blended with the saturation and luminosity in B, which essentially means that the hue information in B is replaced by the hue information in T. However, in running some experiments, I've noticed that when dealing with a very simple document comprised of two layers only, that setting the Blend Mode to Hue also changes the saturation and brightness.
Here are the steps to duplicate the observed phenomena using two regular layers:
  1. Create a new blank document.
  2. Fill with the color that corresponds to the HSB values (0, 70, 50).
  3. Add a new layer above the existing layer (blend mode Normal).
  4. Fill the topmost layer with the color that corresponds to the HSB values (230, 70, 50).
  5. Using the Info panel, the HSB values for the document should read as (230, 70, 50).
  6. Change the Blend Mode of the topmost layer to Hue.
  7. Using the Info panel, the HSB values for the document should read as (230, 70, 50), but instead read as (230, 66, 53).
And here are the steps to duplicate the observed phenomena using a regular layer and an adjustment layer:
  3. Add a Hue/Saturation adjustment layer (blend mode Normal).
  4. Adjust the Hue value in the Properties panel for the Hue/Saturation adjustment layer to be -130.
  6. Change the Blend Mode for the Hue/Saturation layer to be Hue.
The results in both (for me) are identical. Am I misunderstanding the Hue blend mode?
Matt
Photoshop Info:     13.0.1 x64 Extended
OS:                        Windows 7 64-bit
CPU:                      Dual Xeon E5440
RAM:                     16 GB
Video:                    Nvidia GeForce GTX-580
    Sep 3, 2012 10:59 AM   in reply to anonmous
    The blending happens in an HSL model.
    You're making measurements in an HSB model.
    Also, changing the hue while preserving lightness and saturation sometimes would result in illegal values - and those have to be clipped back to valid values (while preserving the hue).  This will result in changes to lightness or saturation.
  • Noel Carboni
    Dec 23, 2006
    Sep 3, 2012 11:59 AM   in reply to anonmous
    anonmous wrote:
    Also, is there a way for the Info panel to display HSL values?
    +1 to that feature request, just for completeness.
    -Noel
    Sep 3, 2012 12:07 PM   in reply to anonmous
    That sounds about right.
    And no, there is currently no way to display HSL in the info palette (which is in need of major work).
