bootsuk 58 posts
Oct 29, 2009
Slideshow speeds up!
Sep 1, 2012 8:17 AM
I have made a new slide show with a dissolve transition and 10 sec delay.
All seems well everything rendered normally timings show correctly under each slide etc.
Show plays normally within Encore however as soon as I burn to disc it all goes wrong.
After the first two or three slides the whole thing just speeds up, instant dissolves all the way through.
Anyone any ideas what could be wrong?
    Sep 1, 2012 8:20 AM   in reply to bootsuk
    More information needed for someone to help... click these links and provide the requested information
    -http://forums.adobe.com/message/4200840
    -http://forums.adobe.com/thread/416679
    -http://forums.adobe.com/thread/419406
    Sep 1, 2012 1:42 PM   in reply to bootsuk
    I seldom do SlideShows in En, but have done a few (back when there was a 99 slide limit), so am really thinking aloud here.
    What are the pixel x pixel dimensions of the JPEG's/PSD's?
    Do you have a music score in the SlideShow?
    Do you have the function to Match Duration of Music (or similar syntax) chosen?
    Did you add the same Transitions to each Image?
    That is about all that I can think of now. I have never seen what you describe, but remember, I do 95% of my SlideShows in PrPro, then Export for authoring.
    Good luck,
    Hunt
    Sep 7, 2012 9:03 AM   in reply to bootsuk
    Brian,
    Those pixel x pixel dimensions should be just fine. Where things get stressed is when one uses the dimensions, right out of the camera. Encore can do some Scaling, but is not the best tool, by a long shot, and one can also run out of resources pretty quickly, when using overly-large Image files.
    Glad that you have found a workaround with the SlideShow Durations.
    As for your Reply # 6, I am at a loss to explain why the Duration would accelerate. Maybe others will see what I am missing.
    Good luck,
    Hunt
    Sep 9, 2012 1:41 PM   in reply to bootsuk
    You are most welcome, and happy authoring.
    Good luck,
    Hunt
