i need help please
Sep 3, 2012 11:54 AM
hi , how are you guys ? i hope you all fine..
here
i have 2 problems the first one is why some sounds files  change after importing  it into flash
and how can i fix that
second problem is why flash asking me to add semicolon !! this is the first time and (i guess) it is because of static type , because i get this problem when i did that(trying to access variable from another class) also i couldn,t fix it after adding semicolon
here are the 2 classes
MAIN CLASS
package
import flash.display.MovieClip;
import flash.events.Event;
import flash.events.KeyboardEvent;
    import flash.ui.Keyboard;
   import flash.media.Sound;
        import flash.media.SoundChannel;
public class MAIN extends MovieClip
  var LINKCONVERT:linkconvert = new linkconvert
  var checkpoint:Boolean
var fireballindex:Array = new Array
var ele:int
var i:int = 0
var FIREBIRD:firebird = new firebird
var SCREAM:scream = new scream
var SOUNDCHANNEL:SoundChannel = new SoundChannel
  public function MAIN()
   addEventListener(Event.ADDED_TO_STAGE,onAddedToStage);
  public function onAddedToStage(event:Event):void
   addEventListener(Event.ENTER_FRAME,onEnterFrame);
    stage.addEventListener(KeyboardEvent.KEY_DOWN,onKeyDown);
    FIREBIRD.stop()
  public function onEnterFrame(event:Event)
FIREBIRD.x = hero.x
FIREBIRD.y = hero.y
if (hero.ELECTRICALSHIELD.stage){
healthbar1.width -=1
if (bat1h != null){
if (bat1h.stage){
  if (hero.hitTestObject(bat1)){
  bat1h.width -= 5
if (bat1 != null){
if ( bat1h != null){
  if (bat1h.width == 0){
   removeChild(bat1h)
      removeChild(bat1)
            removeChild(bat1b)
            bat1b = null
      bat1 = null
      bat1h = null
if (bat1 != null){
if (bat1.stage){
   healthbar1.width -=  5
   if (bat1 != null)
     healthbar1.width -=  1;
   if (healthbar1.width >= 80 && healthbar1.width <= 100)
    zelda1.gotoAndPlay(1);
   if (healthbar1.width >= 60 && healthbar1.width <= 80)
    zelda1.gotoAndPlay(2);
   if (healthbar1.width >= 40 && healthbar1.width <= 60)
    zelda1.gotoAndPlay(3);
   if (healthbar1.width >= 20 && healthbar1.width <= 40)
    zelda1.gotoAndPlay(4);
   if (healthbar1.width >= 0 && healthbar1.width <= 20)
    zelda1.gotoAndPlay(5);
   if (hero.hitTestObject(portal3))
    if (bat1 != null)
     var map4:BACKGROUND = new BACKGROUND  ;
     removeChild(bat1);
     bat1 = null;
     // this doesn't need to be done unless you added a listener outside the Bat1 classs
    }//normal
   }//normal
  }//func
   public function onKeyDown(event:KeyboardEvent):void {
            if (event.keyCode == Keyboard.E)
         if (hero.visible){
  if(checkpoint){
   SOUNDCHANNEL = SCREAM.play()
                                hero.visible = false
        addChild(FIREBIRD)
      if (!hero.visible){
if(FIREBIRD.stage){
  if(!checkpoint){
   if(HERO.marioflying == false){
  SOUNDCHANNEL = LINKCONVERT.play()
                                hero.visible = true
        removeChild(FIREBIRD)
      checkpoint = !checkpoint
} //if event...
   }//fun
}//class
}//pack
HERO CLASS
package
        import flash.sensors.Accelerometer;
        public class HERO extends MovieClip
var MARIOHASFALLEN:mariohasfallen = new mariohasfallen;
var static marioflying:Boolean = true;
var vy:int
var ROARING:roaring = new roaring
                var NIGHTJUNGLE:nightjungle = new nightjungle
var heromovesduringfirefly:Boolean
                var ELECTRICALSHIELD:electricalshield = new electricalshield;
                var fBall:fireball = new fireball();
var fBalla:fireball = new fireball();
  var fBallb:fireball = new fireball();
var fireshooting:Boolean = false
var lastpos:int
                var FIREBALLSOUND:fireballsound = new fireballsound
                var speed:int = 3;
                var dir:int;
                var ELECTRICITY:electricity = new electricity;
                var firespeed:int = 10
                var totalfirespeed = 0
                var i:int
                var fdir:int
                var fireballFlying:Boolean; // keep track of fireball
                public function HERO()
                        addEventListener(Event.ADDED_TO_STAGE, onAddedToStage);
                        addEventListener(Event.ENTER_FRAME, onEnterFrame);
                        stage.addEventListener(KeyboardEvent.KEY_DOWN, onKeyDown);
                        stage.addEventListener(KeyboardEvent.KEY_UP, onKeyUp);
                        gotoAndStop(4);
                public function onEnterFrame(event:Event):void
if(visible){
if(y <325){
  y += 10
  if(marioflying){
   SOUNDCHANNEL = MARIOHASFALLEN.play()
   marioflying = false
  if(y>=325){
  y = 325
  marioflying = true
if(fBall.width > 55){
fBall.width = 55
if(fBall.height > 55){
fBall.height = 55
y += vy
                        x += dir * speed
                        if (fBall.stage)
                                fBall.x += firespeed * fdir;
                                fBall.width += 0
                                fBall.height += 0
                                totalfirespeed += 1
                        if (totalfirespeed == 20)
                                if (fBall.stage)
                                        MovieClip(parent).removeChild(fBall);
                                        totalfirespeed = 0;
                                        // fireball done flying
fdir = dir
                                        fireballFlying = false;
          fireshooting = false;
                        if (event.keyCode == Keyboard.RIGHT)
                                gotoAndStop(2);
                                // is fireball flying?
                                if (fireballFlying == false)
                                         fdir = +1
                                dir = 1;
                                speed = 10
                                if (ELECTRICALSHIELD.stage)
                                        addChild(ELECTRICALSHIELD)
if(MovieClip(parent).FIREBIRD.stage){
speed =30
MovieClip(parent).FIREBIRD.gotoAndStop(2)
                        if (event.keyCode == Keyboard.LEFT)
                                gotoAndStop(1);
                                        fdir = -1
                                dir = -1;
                                speed = 10
MovieClip(parent).FIREBIRD.gotoAndStop(1)
speed =30
                        if (event.keyCode == Keyboard.UP)
                               if (MovieClip(parent).FIREBIRD.stage)
vy = -30
      if (event.keyCode == Keyboard.DOWN)
        vy = 30
                        if (event.keyCode == Keyboard.Q)
                                if(visible){
                                speed = 30;
                                addChild(ELECTRICALSHIELD);
                                SOUNDCHANNEL = ELECTRICITY.play()
                        if (event.keyCode == Keyboard.W)
                                // tell myself a fireball is shot
                                fireballFlying = true;
if(!fireshooting){
fireshooting = true
                                fBall.name = "fb" + String(i);
                                fBall.width = 25;
           fBall.height = 25;
                                fBall.x = x + 20
                                fBall.y = y + 10
                                fireballindex.push(fBall);
          if(this.visible == false){
         if (MovieClip(parent).FIREBIRD.stage){
         fBall.width += 30
         fBall.height += 30
        SOUNDCHANNEL = ROARING.play()
                                MovieClip(parent).addChild(fBall);
if(this.visible == true){
if (!MovieClip(parent).FIREBIRD.stage){
                                SOUNDCHANNEL = FIREBALLSOUND.play()
                                i++;
                                trace(i)
                                trace(fBall.name)
                public function onKeyUp(event:KeyboardEvent):void
                                        removeChild(ELECTRICALSHIELD);
                                        if (SOUNDCHANNEL != null)
                                                speed = 0;
                                        SOUNDCHANNEL = ELECTRICITY.play(1, 1)
                                speed = 0
                                gotoAndStop(3);
                                speed = 0
                                gotoAndStop(4);
                                if (ELECTRICALSHIELD.stage){
       vy = 0
       vy = 0
   //لا اله الا الله
    // there is no god except 1 god
and here is the error message
C:\Users\Owner n\Desktop\project ‫(4)‬ ‫‬\HERO.as, Line 39 1086: Syntax error: expecting semicolon before marioflying.
thank you guys for all the help in all my threads
