Premier Elements 10, Windows 7. I wish to create a new project from 2 previously created projects. I understand I need to share the exisiting projects and then import into the new one. I need to share at the native quality in order to preserve quality. This seems fraught with potential errors in applying the wrong settings. Is there an easier way? How do I apply the correct settings if not?
The original material was shot in HD PAL, to produce a widescreen end product. I would have thought that I needed to import the RAW files rather than an encoded file. The ultimate could be to produce a Blue Ray. It seems wrong that in order to work on the files on another project I am using a new generation rather than originals. Any new generation can result in degradation.
For HD, I like either the Lagarith Lossless, or the UT Lossless CODEC's, for my intermediate files. This article goes into more detail, and has links to each: http://forums.adobe.com/thread/875797?tstart=0.
If one were to also do a DVD, then I would recommend Sharing to DV-AVI from that combined Project, then Importing that into an SD DV Project (PAL in your case), and doing the authoring, with Menu Sets, Chapter Markers, etc., there, using that DV-AVI.
Good luck,
Hunt
As I say in my books, if you are working with hi-def and you plan to assemble your videos for output to BluRay, you should output each segment using the Share/Computer/AVCHD using the M2T 1920x1080 output setting.
This will produce videos that will mix perfectly in a project set up for Full AVCHD 1920x1080.
